Pocket GPS World :: View topic - TTN6 - iPAQ hx4700 - Starts automatically
SimonCatlin
PostPosted: Thu Nov 30, 2006 2:38 pm    Post subject: TTN6 - iPAQ hx4700 - Starts automatically Reply with quote
Whenever I soft reset or turn off and on my iPAQ, it starts TTN6 automatically.
In the windows directory there is a folder called Autorun, which contains another folder called SD card, which contains a program called "autorun.exe". I renamed the Autorun folder to Autorunspc and turned the unit off and on again via a soft reset.
Lo and behold, the directory was recreated and TTN6 restarted.
Is it safe to delete the autorun.exe file?
iPhone5, TomTom, Google maps, Navfree, Viewranger and Apple Maps (ekk)
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
schneid
PostPosted: Thu Nov 30, 2006 4:27 pm    Post subject: Reply with quote
If you install from the DVD to an SD card and I presume purchase the pre-installed version on SD Card that will happen. That is how TT 6 auto-installs itself. If you moved the application from main memory to an SD card it will reinstall the app in maim memory every time.
I had no issues nuking autorun.exe to fix the problem but to be safe you could rename it first. Be sure to check your \windows\startup\ folder to make sure a startup link wasn't installed there too.
The above behavior is another reason I gave up on 6 and sent it back.
SimonCatlin
PostPosted: Thu Nov 30, 2006 11:27 pm    Post subject: Reply with quote
Regretfully, renaming the file folders failed. So I went to the source and renamed the exe it hits on the SD card in the sub directory 2577...
When I next started TT, it stated I had no maps, so I had to re-install the app to make the maps visable again!
Any other ideas greatfully received?
schneid
PostPosted: Fri Dec 01, 2006 1:24 am    Post subject: Reply with quote
I had the map not found issue a couple of times too. Another reason I gave up and returned 6. Have you tried a soft-reset? I think one of the moderators suggested that.
I never did anything with the 2577 directory and autorun.exe.
Are you running TomTom Navigator.exe directly from the \navigator\ directory? You might be using a icon that points to autorun.exe or somewhere else.
Did you make sure a link is not in your \windows\startup\ directory\ ?
