Pocket GPS World :: View topic - Updating 710
Updating 710
rejo
PostPosted: Sun Oct 15, 2006 10:44 pm    Post subject: Updating 710 Reply with quote
Just got a 710 and have been trying to upgrade from version 6.1 to version 6.51 as the tom tom website says this is the latest version.
Have downloaded tom tom home and supposedly when I connect my 710 it will automatically upload any updates.
The problem is tom tom home is telling me there are no updates.
So even though the tom tom website says 6.51 is this an upgrade for the 710 or not.
PostPosted: Sun Oct 15, 2006 10:54 pm    Post subject: Reply with quote
Assuming your PC has the Home application installed and an open internet connection you should dock the TomTom 710, switch it on and when it asks do you want to connect to computer tap yes.
At this point TomTom Home should start and automatically look for updates, if not click File/ Preferences in the home application and make sure the "Check for updated content when i'm logged in and my TomTom device is connected to the computer" is ticked - Mike
rejo
PostPosted: Sun Oct 15, 2006 11:03 pm    Post subject: updating 710 Reply with quote
Hi Mike
Thanks for the very quick responce, had the box already ticked .....any other ideas or am I missing something.
Thanks.
Jo
PostPosted: Sun Oct 15, 2006 11:17 pm    Post subject: Reply with quote
Have you logged in to TomTom Home, if this is a first attempt you might need to setup an account, it only needs your e-mail details etc, if you have done this and it still doesn't work try turning off any firewalls while the TomTom Home checks for updates, it could be a firewall problem (non trusted software) - Mike
timber
PostPosted: Sun Oct 15, 2006 11:29 pm    Post subject: Reply with quote
Mike,
ok untill tonight there may be problems at tomtom's end getting the following error
SERVER ERROR (Sun Oct 15 22:21:58 2006):
connection error
Request: ServiceDiscoveryRequest. Reply: ServiceDiscoveryReply
Server: "sweet.tomtom.com". Path: "/cens/sweet/sd/"
anyone else getting the same see the servererror text file in your home folder Exclamation
rejo
PostPosted: Sun Oct 15, 2006 11:45 pm    Post subject: updating 710 Reply with quote
Thanks to everyone but still no joy, I am logged on to home and disconnected the firewalls but it still says no updates...... what next.
Pedro2NR
PostPosted: Mon Oct 16, 2006 12:35 am    Post subject: Reply with quote
Try updating to 6.02 first from TT's site.
Scroll down in link.
BodgerBaz
PostPosted: Mon Oct 16, 2006 8:15 am    Post subject: Reply with quote
Rejo,
Did you see it download any files when you first docked it?
Was one of them a new version?
To check the current state of your application software :-
1. Connect up your GO.
2. Make a backup.
3. Click on the 'Check for updates' button.
4. Click on to 'Download Your Updates' button.
This will display the updates available in the middle window and what's on the SD card on the right hand window.
3. Hover your mouse pointer over the SD card's Application and read off the version number.
4. Do the same with the middle column.
5. If the version sat on your PC is newer than the one on the SD card press the install button.
Hope this helps
rejo
PostPosted: Tue Oct 17, 2006 3:28 pm    Post subject: Updating 710 Reply with quote
Ok, it's finally sorted.
DON'T ASK ................
PostPosted: Tue Oct 17, 2006 3:50 pm    Post subject: Reply with quote
Oh go on let us know, it might stop others having the same trouble 8) - Mike
Pedro2NR
PostPosted: Tue Oct 17, 2006 4:24 pm    Post subject: Reply with quote
I knew someone who overlooked the green install button on the top right corner.
BodgerBaz
PostPosted: Tue Oct 17, 2006 6:29 pm    Post subject: Reply with quote
Was he a friend of yours? Wink
oe6jwd
PostPosted: Thu Oct 19, 2006 3:15 pm    Post subject: Reply with quote
Mike,
connection error
Ich habe das gleiche Problem am Wochenende festgestellt.
Den Server sweet.tomtom.com konnte ich auch nicht mit dem IE oder FF erreichen
Vom Büro aus dagegen schon
Mir scheint, daß es da irgendein routing problem gibt, je nach Provider funktioniert es oder nicht....
Daheim: Inode Crying or Very sad
Büro: AcoNet :D
*KD*
22.053 (15 May 24)
