Pocket GPS World :: View topic - TomTom 910 external aerial
arthurharding
PostPosted: Fri Oct 13, 2006 12:01 am    Post subject: TomTom 910 external aerial Reply with quote
I have just upgraded from one of the original tomtom go's to a 910 and am confused about the external aerial on my old go I had to use the external aerial to get a signal and the unit came with a seperate mounting for it. I notice that on th e610 everything plugs into the window clamp so am I able to use the same aerial if I cut off the lead and terminate a plug onto it??
Also the new window clamp looks fairly useless as the 610 is much more heavy and feels that it will fill off the window a lot unless the 610 rests on the dashboard so that the weight is off of the windon clamp and that is just keeping it in place
Also looks like the fitting to clip it onto the window clamp is arkward to place and remove compared to the old model unless I am doing something wrong
Help me out !!! PLEASE
PostPosted: Fri Oct 13, 2006 7:30 am    Post subject: Reply with quote
The 910, in nearly all circumstances, does not need an external aerial.
The wieght of both units is almost identical.
As to the mount, there are several Topics on this that can be found by Searching for droop. One is
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=46882&highlight=droop
