Pocket GPS World :: View topic - Image export help needed
backontrack
PostPosted: Wed Sep 26, 2007 12:19 am    Post subject: Image export help needed Reply with quote
I have memory map OS edition version 5 and was wondering if anyone knows any tricks to save a map and overlayed route as an image, jpeg etc so it can be sent to people who do not have the program to view. I realise the image export function is defuct due to os copyright laws but was wondering if anyone had found any neat ways to do this as it is the primary rteason I just shelled out all this money on a new pda and gps! Thanks, in advance.
AllyCat
PostPosted: Wed Sep 26, 2007 1:04 am    Post subject: Reply with quote
You can create a .PDF using one of the many PDF-writer programs (I use the freeware "PrimoPDF"). The program appears as a "virtual printer" which you can send the map images to, like any normal printer.
Cheers, Alan.
PostPosted: Wed Sep 26, 2007 8:02 am    Post subject: Reply with quote
With MM displayed on the PC press "CTL and Print Screen" an image of the entire MM application will be placed on the PC clipboard, next fire up Paint or a more capable picture editor package and press "Ctl and V" you can do what you want with the image now - Mike
backontrack
PostPosted: Wed Sep 26, 2007 8:22 am    Post subject: Reply with quote
Excellent, thank you.
Mortiki_UK
PostPosted: Thu Oct 18, 2007 11:29 am    Post subject: Reply with quote
Not a query on this issue but just a general question really. Mike, why would you use CTRL and PRINTSCREEN when the PRINTSCREEN button on its own does exactly the same thing?
Garmin Etrex H
Memory-Map V5 5.2.7
PostPosted: Thu Oct 18, 2007 11:58 am    Post subject: Reply with quote
I'm not even sure CTRL+PRTSCRN is a valid command, maybe Mike was thinking of ALT+PRTSCRN which only captures the active window and not the entire desktop?
PostPosted: Thu Oct 18, 2007 3:35 pm    Post subject: Reply with quote
Since I cleaned the keyboard a while ago I suspect I put the CTL and ALT keys back the wrong way around hence the confusion sorry Embarassed I guess I just got used to it being slightly different - Mike
22.034 (27 Mar 24)
