Pocket GPS World :: View topic - Installing Tomtom on a C510E?
Simebaby
PostPosted: Wed Aug 02, 2006 3:21 pm    Post subject: Installing Tomtom on a C510E? Reply with quote
Hi All
I just wondered if this was possible (in theory) with an unlocked Mio - as it's just a windows CE device behind the scenes. Which version of Tomtom would it need?
As I said, just a theoretical question - I've no plans to try this.
TIA
Si.
lbendlin
PostPosted: Wed Aug 02, 2006 3:30 pm    Post subject: Reply with quote
I have successfully run TomTom Navigator 5.21 on the C710
Be aware that you need to spend a Product Code/Activation for that.
Lutz
TomTom/TeleAtlas NAVTEQ
Simebaby
PostPosted: Wed Aug 02, 2006 3:32 pm    Post subject: Reply with quote
Thanks for the quick reply. Which version of Tomtom Navigator 5 did you use (i.e. is there just a PDA / WinCE version, or are there different versions for different processors etc?).
lbendlin
PostPosted: Wed Aug 02, 2006 3:44 pm    Post subject: Reply with quote
There's just one version. TomTom 5 is only available for ARM processors, and doesn't use any Pocket PC API calls. So it runs fine on CE systems.
Lutz
Simebaby
PostPosted: Wed Aug 02, 2006 3:50 pm    Post subject: Reply with quote
Thanks again. I may be able to purchase TT through work, so I would be tempted to give it a go - but I'm assuming there's no way to test without buying TT Navigator (i.e. Tomtom don't provide a demo version or similar)?
lbendlin
PostPosted: Wed Aug 02, 2006 7:34 pm    Post subject: Reply with quote
There's no demo version but you can install and run TomTom to the point where it says "no maps found"
Lutz
Simebaby
PostPosted: Wed Aug 02, 2006 9:18 pm    Post subject: Reply with quote
Unfortunately didn't work for me. Managed to borrow a copy off someone at work, but couldn't get the install to work. Autorun didn't work at all, and trying to run the ttn.cab file myself, nothing happens. all the other modules (gps.cab etc) install fine, just the ttn.cab doesn't do anything.
Shame, but for some reason doesn't seem to work on the C510. What version of Windows CE does the C710 have?
lbendlin
PostPosted: Thu Aug 03, 2006 4:51 am    Post subject: Reply with quote
Windows CE 4.2
You can unpack the CAB file and copy the two files (TomTom Navigator.exe and data.chk) manually.
Lutz
Simebaby
PostPosted: Thu Aug 03, 2006 10:29 am    Post subject: Reply with quote
Sort of got it working... obviously can't get past the registration, so I don't know if it would work once activated. Is there any way at all that I can "test" before buying - as I don't want to get work to shell out for the full product only to find it didn't work (and I'm assuming it couldn't be returned, as it's software and the seals would've been broken).
Palexr
PostPosted: Thu Aug 03, 2006 12:13 pm    Post subject: Reply with quote
Just a question from an ignoramus. Why are you trying to get TomTom software to work on a Mio? What would the advantages be?
cheers
alex
Simebaby
PostPosted: Thu Aug 03, 2006 1:17 pm    Post subject: Reply with quote
Temporary solution so I could use the PGPS speed camera database (which doesn't work currently on the C510E).
lbendlin
PostPosted: Thu Aug 03, 2006 5:03 pm    Post subject: Reply with quote
No, there is no legal way.
Yes, it will work.
Lutz
buddysaab
PostPosted: Sun Aug 06, 2006 4:04 am    Post subject: Installing Tomtom on a C510E? Reply with quote
What GPS settings did you use on the C710?
I have tried all the settings but it will not work.
Thank you in advance!
Simebaby
PostPosted: Tue Aug 08, 2006 12:49 pm    Post subject: Reply with quote
Having problems... installed (not without problems in istelf, manual unzipping etc), but when loading after registration, the application just hangs - any ideas?
toibs
PostPosted: Tue Aug 08, 2006 2:27 pm    Post subject: Reply with quote
Lutz,
Is this a complete replacement "hack" so to speak - i.e if you have to do a hard reset does it return to the original Mio stuff??
If so i might be tempted to give it a go until they get the POI's sorted...
Paul
22.054 (22 May 24)
