rotty66 Occasional Visitor
Posted: Mon Aug 07, 2006 8:01 pm Post subject: TT510 upgrade SD card - no maps found |
Upgraded my TT510 to a 2gb SD card but can't get it to work , get a "no maps found" message
I have tried to methods of doing it , both by copying original card to PC and copying to new card , also tried it by using the backup/restore feature in the TT application
any ideas ?
thanks |
Oldboy Pocket GPS Moderator
Posted: Mon Aug 07, 2006 8:12 pm Post subject: |
Have you tried the pin-in-the-hole reset method? _________________ Richard
ColinS Lifetime Member
Joined: 30/03/2003 17:56:49 Posts: 120 Location: Dorset, UK
Posted: Mon Aug 07, 2006 9:13 pm Post subject: |
Does the original SD card still work?
I upgraded mine using backup and restore and that worked fine. Maybe it's the card, do you have another one you could try. Also suggest that you publish the make and model of the card just in case others are using it okay. _________________ Colin
Honda Jazz EX-Navi MKIII |
Posted: Mon Aug 07, 2006 9:23 pm Post subject: |
thanks for the replies
yes I have tried the reset
the card is a cheapo one , says "keymem" on it
original card still works fine |
Posted: Mon Aug 07, 2006 9:49 pm Post subject: |
Well I can't see that you've done anything wrong so my guess is that the card is incompatible. _________________ Colin
Mullet Frequent Visitor
Posted: Mon Aug 07, 2006 11:01 pm Post subject: |
rotty66
Did you format the card? |
Posted: Mon Aug 07, 2006 11:26 pm Post subject: |
Mullet wrote: | rotty66
ah , this is where we head down the rotty is a plonker line , didn;t realise I had to
will format and try again |
Posted: Mon Aug 07, 2006 11:56 pm Post subject: |
seems to be working now , formatted as FAT and recopied the files
thanks for all your help folks
I will now go and find a corner to be embarrassed in :P |
Posted: Tue Aug 08, 2006 12:11 am Post subject: |
Pleased its sorted, we can all make oversights. |
bigyun2000 Regular Visitor
Joined: Oct 12, 2004 Posts: 64 Location: Rotherham, South Yorkshire
Posted: Fri Aug 25, 2006 6:18 pm Post subject: |
Hi all
I got same problem.
I use the Kingston 512mb Elite Pro card (can't get the map to worl always wants activation. When i give it all details it fails) Original is fine.
Also tried on my Sandisk 2GB and exactly same problem.
Have formatted both in FAT
Have used the copy method and the backup/restore method
Been at it about 4 hours now :x
Any please HELP !!! _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
Version 9.510 (2039, 4/4/2013) | OS: 842337 | MAP v910.4892 | iPad Mini | iPhone 5 | |
Posted: Fri Aug 25, 2006 7:24 pm Post subject: |
Ha sorted it out at last.
Here how i did it.
RESET
Installed TT Home
Asked me to install another required file (downloaded automatically)
Run through the setup on PC rather than unit and worked fine.
So all the setting up was done on the PC (it had a duplicate TTG 510 you can use just as the unit itself)
Only problem is now everytime i connect. I get a hugh list of speed cams to download which are not relevant for me
Any ideas on this please _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
Posted: Fri Aug 25, 2006 7:26 pm Post subject: |
Your not going to believe this. As soon as i disconnect from the cradle i gotta go through it all again
Same problem as my first post :X _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Sun Aug 27, 2006 3:22 pm Post subject: |
contact Support about this. They have a fix available. _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
Posted: Mon Aug 28, 2006 2:33 pm Post subject: |
Thanks.
It worked fine _________________ Regards
Bigyun2000 UK
TOM TOM GO 530
