Pocket GPS World :: View topic - TomTom and UDrive sharing GPS on Palm
ItsMikeE
PostPosted: Thu Aug 24, 2006 4:57 pm    Post subject: TomTom and UDrive sharing GPS on Palm Reply with quote
I have two GPS applications for my Palm.
TomTom for the UK and UDrive for Israel (TomTom is not available for Israel).
UDrive cannot find the GPS and their support say that TomTom must be locking the GPS.
I have tried rebooting the Palm and also removing the Navigator application, but that did not help.
Is it likely that TomTom is causing the problem?
If so, is there anything other than a hard reset which will free it up?
lbendlin
PostPosted: Fri Aug 25, 2006 3:55 am    Post subject: Reply with quote
No, after a soft reset the port is free, TomTom is not blocking it. Your other application may need to be setup for a different port or speed. What type of receiver are you using?
Lutz
TomTom/TeleAtlas NAVTEQ
ItsMikeE
PostPosted: Fri Aug 25, 2006 10:56 am    Post subject: Reply with quote
I have both a TomTom (Sirf3) and a Holux 236.
I have tried it using the TomTom only
lbendlin
PostPosted: Fri Aug 25, 2006 6:36 pm    Post subject: Reply with quote
I have no problem running Mapopolis or TomTom on the Tungsten T3, using the TomTom BT receiver. Is your program actually working with BT receivers?
Lutz
ItsMikeE
PostPosted: Fri Aug 25, 2006 10:48 pm    Post subject: Reply with quote
According to the vendors it does work with BT GPS, and the only times they have seen problems is when TT is installed on the Palm.
I had been hoping there was a set of instructions, like the one for TT on PPC that I could use.
They are arranging to get one of their engineers to phone me and talk me through the problem.
I'll post the results later.
ItsMikeE
PostPosted: Wed Aug 30, 2006 11:03 am    Post subject: Reply with quote
Spoke to UDrive support yesterday, and now I can switch between TomTom and UDrive.
There were some advanced menu options, which are in the full installation manual (Hebrew only), but not in the Quick Start Guide (Hebrew and English).
If I use TomTom in between two sessions of UDrive, then I have to re-select the GPS, but that is a very minor irritation.
22.053 (15 May 24)
