Ash10 Pocket GPS Verifier
Posted: Thu Jul 27, 2006 11:08 am Post subject: |
PaulB2005 wrote: | As most PCs will be switched off and on once a day does the application need to run all the time? Why not just have it check on start up and then close down if their is no update?
If i do Quit the application what's the advantage of having it remove the start up regsitry entry? It means if i need to kill the app at any time then i loose the auto start function. What if i want to kill the app but have it auto start next time? |
Don't forget that machines are often hibernated, or left in standby - so it's not quite as simple as having it switched on or off.
Camera Manager is designed to stay loaded until you specifically tell it otherwise (by clicking on the Quit button). If you really want to override the default behaviour, you can always put the application (or a shortcut to it) in your Startup directory.
Can I ask what advantage you think there is to not having CM loaded all the time? |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Thu Jul 27, 2006 11:14 am Post subject: |
PaulB2005 wrote: | . . . As most PCs will be switched off and on once a day does the application need to run all the time? Why not just have it check on start up and then close down if their is no update? |
My PC's on 24/7. If the application just checked on start-up it would virtually never check!
I don't see what the problem is with having such a small app running all the time. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21 |
Posted: Thu Jul 27, 2006 11:37 am Post subject: |
Quote: | Can I ask what advantage you think there is to not having CM loaded all the time? |
The database is only released once a month, so for 29 days, 23 hours, 59 minutes and 30 seconds of the month it's doing nothing! Not much of an advantage. Also i don't like un-necessary apps running in the background.
I haven't got a problem with the app itself but the way there is no flexibility in it's deployment. Many people who run it probably don't know or care that it's running all the time. But some do and I'm sure I'm not the only one. |
Posted: Thu Jul 27, 2006 12:47 pm Post subject: |
PaulB2005 wrote: | Also i don't like un-necessary apps running in the background. |
Oh boy, are you running the wrong OS... |
Posted: Thu Jul 27, 2006 1:23 pm Post subject: |
Quote: | Oh boy, are you running the wrong OS... |
OK then ...i don't like MORE un-necessary apps running in the background than XP already provides.
If it's going to be like that i'll learn to live with it. Cheers. |
missing_user
Posted: Fri Jul 28, 2006 9:26 pm Post subject: |
Ash10
Are your links up to date?
http://tinyurl.com/qwwwa
It seems the link I followed gave me an old download! |
Posted: Sat Jul 29, 2006 9:27 am Post subject: |
strumble wrote: | Are your links up to date?
The links are fine - you're just using the wrong one!
Try http://tinyurl.com/nvlm4 ;) |
missing_user
Posted: Sat Jul 29, 2006 9:31 am Post subject: |
Why then do you still have the wrong one in your signature?
It was that link I was using. |
Posted: Sat Jul 29, 2006 7:53 pm Post subject: |
strumble wrote: | Why then do you still have the wrong one in your signature? |
I don't - that's for a completely different application (Camera Updater)!
I am allowed to write more than one, you know... |
missing_user
Posted: Sat Jul 29, 2006 8:26 pm Post subject: |
I am now hiding under a stone!
Sorry |
socco Occasional Visitor
Posted: Tue Aug 01, 2006 7:41 pm Post subject: |
hi
does this work with a nuvi 360? |
Posted: Tue Aug 01, 2006 9:51 pm Post subject: |
socco wrote: | does this work with a nuvi 360? |
It should do, but I can't say for sure as I don't have a Nuvi
Try it for yourself, and don't forget to post your findings here! 8) |
richard5 Occasional Visitor
Posted: Fri Aug 04, 2006 11:35 am Post subject: |
Hi Ash
Had Camera Manager all working fine until yesterday, when it crashed and shut down for no apparent reason.
Tried re-starting and it said "Beta Version Expired"
Just downloaded it again from your website and all is working fine again (it even kept my old settings etc)
So all is OK again, just thought I'd let you know.
Cheers for excellent software
Richard |
trevf Regular Visitor
Posted: Mon Aug 07, 2006 8:54 am Post subject: |
Hi Ash, been away, hence no feedback.
I've noticed the following:
When app loads, full screen is always shown for a split second. Could it be run minimised to the system tray?
Secondly as I said I have been away (and wih no web access - scary). When starting the PC now it reports a server connection error (I guess to PGPSWorld). Could this error be a balloon instead of being a Dialogue Box?
Apart from that all seems good. Keep up the good work!!! _________________ Garmin i3
Firmware 3.4 |
Woms Occasional Visitor
Posted: Thu Aug 10, 2006 1:08 pm Post subject: |
socco wrote: | hi
Socco, it works fine with a Nuvi 310, so assume a 360 is also fine.
Ash, excellent work. :D |
