Pocket GPS World :: View topic - PC lock-up
PC lock-up
gardgas
PostPosted: Sat Jul 01, 2006 1:31 am    Post subject: PC lock-up Reply with quote
I wonder if any of you clever chaps out there can help. As it turns out its not specifically a TomTom problem, but I first noticed it when trying to connect my 700 to the pc. Went to plug to 700 into the USB port and my PC just totaly locked up, not even the 3 fingered salute would sort it. Initially I thought it was the TomTom at fault, but its screen showed it was connected. I disconnected the GPS, and it started up and worked ok, so then tried it again on the PC after restarting that. Same thing happened. So I tried another USB device in the same socket, a webcam, and it worked ok. Then I tried a USB memory stick, the PC locked-up again same as with the GPS. So to me it seems that my PC has a sudden dislike to USB mass storage devices. Any ideas what might be wrong, I need to update my speed cams. Running Win XP Home if thats ant help.
Nigel
Tumbleweed
PostPosted: Sat Jul 01, 2006 9:56 am    Post subject: Re: PC lock-up Reply with quote
gardgas wrote:
Nigel
Try deleting the device in device manager so it gets found and added again on reboot.
Tw
delboy0754
PostPosted: Sat Jul 01, 2006 10:08 am    Post subject: Reply with quote
How many USB devices have you connected, you may well be using all the power available to your USB ports..
You may need a Powered USB hub.
Try disconnecting all your USB devices, then try you Go 700 by itself.
