Pocket GPS World :: View topic - Transfering trips from desktop to pocket PC
sven
PostPosted: Wed Mar 03, 2004 8:22 am    Post subject: Transfering trips from desktop to pocket PC Reply with quote
When planning trips on the desktop route planner (NOT using the data Download Wizard), are you supposed to be able to download the .trp files using the Download Wizard?
The help menu suggests you can, but this doesn't seem to be the case. The trips in the Download Wizard are saved as .gls files anyway.
However, if you copy and paste the .trp files directly into your SD card and then delete the starting point, they do work, provided you have the area map for the region downloaded.
It's a lot easier to plan and edit routes when you're in the normal routeplanner rather than the Download Wizard trip planner.
23.052 (14 May 25)
