Pocket GPS World :: View topic - TT One and Rearranging the Icons??
MR_TiGGer
PostPosted: Fri Apr 21, 2006 6:30 pm    Post subject: TT One and Rearranging the Icons?? Reply with quote
Is there some software of some trick to rearranging the icons?
It's silly I know but when I want to "Navigate to" I want the "postcode on screen one and the "Point of Interest" on screen two, basically swap them.
The 7 digit postcode search is possably the most usefull function ever, and the reason I went to TT one.
Silly I know but any help would be appriciated, thanks.
PostPosted: Fri Apr 21, 2006 7:42 pm    Post subject: Reply with quote
you cannot rearrange submenus. But you might be able to take the desired item from the submenu and put it into the main menu. Try the online menu generator.
MELennium
PostPosted: Fri Apr 21, 2006 9:49 pm    Post subject: Reply with quote
Download this Menu Builder from the site below, it's very good:
http://www.gregoryduncan.com/ttmd/index.php
TomTom Go 910 (3) v.6.522 Map Western Europe v.650 with useless TMC receiver
Ex. owner TomTom 910 (2) Returned Faulty
Ex. owner TomTom 910 (1) Returned Faulty
Ex. owner TomTom One v.5.420 Map UK v.605
Ex. owner Garmin i3 v.2.7 Map UK V.7
MR_TiGGer
PostPosted: Fri Apr 21, 2006 11:01 pm    Post subject: Reply with quote
Appriciate that, but the one Icon that's missing is the Postcode one.
So god knows what will happen if I install a new menu, so thanks but I'll need something else ... if it exists Question
Unplugged
PostPosted: Sat Apr 22, 2006 8:49 pm    Post subject: Reply with quote
if its missing then the ZIP folder or the UK.POSTAL file is missing from it.
MR_TiGGer
PostPosted: Sat Apr 22, 2006 9:03 pm    Post subject: Reply with quote
Could you explain that please, so a small child who is blind could understand Wink
I would really like to get this menu customized to to my way of working, rather than the other way round.
PostPosted: Sun Apr 23, 2006 9:19 pm    Post subject: Reply with quote
I think unplugged may have got the wrong end of the stick....
If I understand correctly, you are saying that the Postcode icon is missing from the menu builder application, but he thinks that it is greyed out on your unit, (as it would be if the postcode files he mentions were not on your TomTom).
It's a shame that the menu builders don't seem to have ALL the icons available, but it might be worth trawling back through this and the Mytomtomgo forums, because there was quite a bit of inestigative work done on them a few monthsa ago, and some extra undocumented bits were found. Also I think the on-line and the download versions of the menu builder were slightly different too.
MR_TiGGer
PostPosted: Sun Apr 23, 2006 9:49 pm    Post subject: Reply with quote
100% correct mate, on the "Menubuilder" there is no postcode Icon, so without it, the whole exercise is pointless 'for me'
So if someone knows the work around, I'll appriciate it :D
999tommo
PostPosted: Thu May 18, 2006 12:53 pm    Post subject: Reply with quote
I have downloaded this menu builder and having created a custom menu, my 'Navigate to Postcode' works fine. There is no icon for it, because the option is accessed via the 'Navigate to" icon. Perhaps I'm missing your point. Can you clarify it please ?
Tommo...
Regularly absent, but still here in spirit !
MR_TiGGer
PostPosted: Fri May 19, 2006 8:29 pm    Post subject: Reply with quote
I'll try 8O
Right then I wanted to use the Menu builder so when I "Navigate to.." I wanted "Postcode on the 1st page not the 2nd as it's the most popular option I use.
On the "Navigate to" page 1 there's Home, Favourite, address, Recent & POI
I want the POI moved to page 2 and Postcode moved to page 1
The rest of the icon layout is fine as now I got it set up I don't need to alter it much
999tommo
PostPosted: Sat May 20, 2006 5:23 pm    Post subject: Reply with quote
Ahhhh.. Sorry, I was a bit thick before. To my knowledge, you can re-arrange all the main menu icons to your heart's content, but sub-menu icons are stuck and only accessible via the main icons.
Tommo...
