davidhicks Occasional Visitor
Posted: Fri Mar 24, 2006 8:53 pm Post subject: Mounting Tom Tom Rider on Ducati 996 |
I've just got one of these as a birthday present for my Dad and his Pan European. I'm quite impressed, but can't see any way to mount one to my bike - a Ducati 996. Anyone done it or got any suggestions for an elegant solution? |
Mr_Gonzales Regular Visitor
Joined: Oct 05, 2005 Posts: 123 Location: Mmm...medway
Posted: Mon Mar 27, 2006 1:23 pm Post subject: |
Drop me a PM/email address and I can email you some pics of mounts on various bikes I've been working on. |
pointmandk Occasional Visitor
Posted: Mon Mar 27, 2006 7:02 pm Post subject: |
I'm searching for a solution to mount the TT Rider onto my Honda CBR600 '93, and will therefor hear, if you might have done an installation on this model? |
Posted: Tue Mar 28, 2006 1:27 pm Post subject: |
On most sportsbikes (the ducati and the CBR included) the two best options are to mount through the spindle nut (central position) or to mount off of a bolt near the clip on bars, where there are usually several bolts that can be used (though the unit will sit off to the left or right)
Someone else on this forum mounted off of the windscreen (used a spare suction mount with a hole drilled through it).
Again, PM me with an email address if you wanty any pics of the bikes/mounts I've worked on - every bike is slightly different but there's only a few designs of mount.
As I'm aware, all Honda bikes can also run a mount from one of the two screws that hold the fuel tank down (you can see them down between the headstock and tank) but check that the CBR has these bolts visible and accessible. The Ducati may be the same - I know my Suzuki can mount from there as well. |
chrisdhall Occasional Visitor
![](modules/Forums/images/avatars/4447727934239ba7be9898.jpg)
Gmonkey Frequent Visitor
Joined: Oct 17, 2005 Posts: 390 Location: Washington DC
Posted: Thu May 04, 2006 5:36 pm Post subject: |
Chris - what kind of system do you use for listening to the vioce commands? |
Posted: Thu May 04, 2006 10:25 pm Post subject: |
Currently it is wired to a rather ancient Collet Comunicator 49 via its audio socket. crude but effective! |
