darrah Occasional Visitor
Posted: Wed Aug 02, 2006 6:58 pm Post subject: |
Also what is Eggnos?
Does anybody else find the distances quoted between places to be wholly inaccurate, From my house to a friends is said by garmin to be 52ish miles when in fact it is nearer 80. |
Posted: Wed Aug 02, 2006 7:29 pm Post subject: |
For the Eggnos question please have a read through THIS it will explain far more than just this one parameter.
For map updates, what version of map is your i3 using at the moment? (Settings/ Map/ Map Source) if it is version 7 then you can get a free upgrade by contacting Garmin (you need to send off the little Transflash card to them for upgrade) if it states version 8 then you have the latest map for the unit.
Distances are calculated in a straight line, something the Romans tried to do when road building began some time ago, sadly the roads are no longer straight and the actual route distance can be considerably different - hence the discrepancy you are seeing, I had to drive 9 miles on Saturday to cover a 3 mile distance for the same reason - Mike |
karlr Occasional Visitor
Joined: Aug 02, 2006 Posts: 3 Location: Shrewsbury, UK
Posted: Wed Aug 02, 2006 11:13 pm Post subject: |
I've just bought a Streetpilot i2...and updated the FW to 3.10. Where do I get the old Firmwares, just in case 3.10 plays up?
So far today (UK), no complaints with it..accuracy etc is spot on. |
mikemccafferty Occasional Visitor
Posted: Wed Aug 02, 2006 11:50 pm Post subject: |
to get an accurate milage from streetpilot. first switch off gps, then set current position (your start point) then navigate to your destination when complete go to review turns press the centre wheel once then advance to last turn this gives you time for journey and milage based on directions your streetpiolot has worked out. |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Wed Aug 02, 2006 11:51 pm Post subject: |
Try page 3 of this thread. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1115.12043
Samsung Galaxy S21 |
Posted: Wed Aug 02, 2006 11:53 pm Post subject: |
Sorry. Quote: | Try page 3 of this thread. | was meant for karlr _________________ Anita
UK map 1115.12043
Posted: Thu Aug 03, 2006 7:20 pm Post subject: |
Stunning! Thankyou Anita. :D
I had my first "Streetpilot crash" today using v3.10 on a route that worked perfectly well with 2.90 yesterday.
Going round a roundabout, I heard "take second ex..", and then nothing for the rest of the route. When I got to my destination, I looked at the screen on my i2 and it was stuck on that roundabout, with the instruction on screen.
I ended up powering down and back up..then it took ages to find a satellite lock. Then on a dead straight road, it suddenly told me to "turn right" and "take the 3rd exit at the roundabout".
There is no roundabout in that area..we just cracked.. Back to 2.x she goes. |
galaxy111 Occasional Visitor
Joined: Mar 01, 2006 Posts: 42 Location: Cheshire, UK
Posted: Tue Aug 08, 2006 9:08 am Post subject: v. 3.0 Firmware Installed |
I've just bought a second Streetpilot i3 (for my daughter) on the latest deal from Comet at £99 - a bargain, and was pleased to find that it's the older version with the City Navigator v.8.0 maps on a mini SD card, which means I can load up plenty of additional POI's without a problem. What isn't so good is the fact that it's version 3.0 of the software that is also loaded. I've always used v 2.7 of the software on my first i3 and have never been tempted to upgrade it, thanks largely to the feedback on this website about other owners tales of woe.
So my question is - should I immediately reload v 2.7 to overwrite the installed v 3.0, or am I better upgrading to v 3.1? There doesn't seem any point in leaving it as it is. Any comments please from people that have tried the upgrades. _________________ Cheers,
Garmin Streetpilot i3 (V.8 maps, v.2.7 F/w) |
Posted: Tue Aug 08, 2006 11:29 am Post subject: |
I have downloaded V3.1 and as yet had no real problems with it,my map version is also #8. |
Coaster2 Lifetime Member
Posted: Tue Aug 08, 2006 2:27 pm Post subject: |
I certainly would. I've tried all versions and you can't beat 2.7. |
Posted: Tue Aug 08, 2006 10:05 pm Post subject: Re: v. 3.0 Firmware Installed |
galaxy111 wrote: | I've just bought a second Streetpilot i3 (for my daughter) on the latest deal from Comet at £99 - a bargain, and was pleased to find that it's the older version with the City Navigator v.8.0 maps on a mini SD card, which means I can load up plenty of additional POI's without a problem. What isn't so good is the fact that it's version 3.0 of the software that is also loaded. I've always used v 2.7 of the software on my first i3 and have never been tempted to upgrade it, thanks largely to the feedback on this website about other owners tales of woe.
So my question is - should I immediately reload v 2.7 to overwrite the installed v 3.0, or am I better upgrading to v 3.1? There doesn't seem any point in leaving it as it is. Any comments please from people that have tried the upgrades. |
try it first if it works ok leave well enough alone if u get problems then go back to 2.7 |
Posted: Tue Sep 19, 2006 8:30 am Post subject: |
Anyone have any knowledge of 3.2? |
bluebell3 Occasional Visitor
Posted: Wed Oct 04, 2006 8:26 pm Post subject: i3 - v 3.0 Camera files will not load |
Hi there
Followed Anitas instructions to the letter and did find the files in csv format but device says I have too many POIs-Are UK camera files pre-loaded on this device?IF so they do not work on my device-If not, i cannot install then as it says I have too many POI's-How do I delete unwanted POI's in order to install the camera files. |
Posted: Wed Oct 04, 2006 9:02 pm Post subject: |
Have some how managed to load the files-only prob is that the alert is triggered at 19 mph in a 30 area so its boing boing almost constantly. how can I access the files to alter the setting-i thought that the i3 may have been shon in My computer but it doesnt#
Sorry to be such a pain |
Posted: Wed Oct 04, 2006 9:18 pm Post subject: |
If you'd used the search button (above) and typed in 19 mph, and clicked on 'search for all terms' you'd have found pages and pages of posts, showing this question has been asked, and answered, many, many, many times before.
When you use POILoader to transfer the POIs to your i3, on the screen where you select the directory where the POI files are to be found, make sure you also change the units from metric to feet and mph. Also, in the i3's settings menu go to Units and make sure Statute is selected. _________________ Anita
UK map 1115.12043
