Pocket GPS World :: View topic - TT Mobile 5 - Voices
GaryL
PostPosted: Sun Apr 02, 2006 8:54 pm    Post subject: TT Mobile 5 - Voices Reply with quote
Does anyone know a cure for this :
When navigating any download voice is unable to give directions clearly.
all instructions are in broken speach, but if you were to use the test function when changing a voice the direction are perfectly clear.
The error seam to have occured since i purchased an upgraded map a few days ago.
Thanks in advance if anyone knows a fix.
PostPosted: Sun Apr 02, 2006 10:21 pm    Post subject: Reply with quote
Gary, were the voices you "downloaded" actually intended for the device you are using, the voice files for PPC are constructed at a different sampling rate than those intended for a mobile "smart phone" device - just a thought - Mike
GaryL
PostPosted: Mon Apr 03, 2006 12:24 am    Post subject: Reply with quote
I selected the voices from Ray's Website and download the john clease voice from tomtom i was assuming the tommtom one would be at the right rate.
I have also now removed all the POI's except the speed cameras, after reading that it could be the pois that are causing a problem, will wait untill tommorow to test.
Thanks for responding.
PostPosted: Mon Apr 03, 2006 7:52 am    Post subject: Reply with quote
Gary, you need to disable ALL the POI then configure the cameras to appear using "Warn when near POI" its in Change Preferences/ Manage POI, As you are using Rays voices why not try one of the custom voice warning files as well to go with the nav voice, the Liz set-up if very impressive on the PDA, not heard it yet on a phone though - Mike
GaryL
PostPosted: Tue Apr 04, 2006 12:36 am    Post subject: Reply with quote
Thanks for the reply have made the required changes.
Now just need to work out how to make my own data.chk file that actully works on the 6680..
I have tried various methods but now seam to allow me to change one of the warning to one i would to use for say informing me that i am near an LPG petrol station.
