Pocket GPS World :: View topic - Navman 3450 Drivers Problems
zanusso
PostPosted: Sun Aug 15, 2004 10:17 pm    Post subject: Navman 3450 Drivers Problems Reply with quote
I have an ipaq 3970 with wince2002 and a Navman 3450 i have installed SmartST Pro, Gps info, Serial driver 3.1.6 and rom update.
It works with SmartST and TomTom but i'm not able to find the gps port with Destinator 3 or other programs like Vito Navigator II. I've tried to force the port 5 or 6 but nothing.
I've tried to uninstall and reinstall all the programs but no way ...
Any body can halps me ?????
Please ?????
lbendlin
PostPosted: Sun Aug 15, 2004 10:45 pm    Post subject: Reply with quote
as far as I can recall it is on COM4, and you need to set the speed to 57600
Lutz
TomTom/TeleAtlas NAVTEQ
zanusso
PostPosted: Sun Aug 15, 2004 10:57 pm    Post subject: Reply with quote
i tried also COM4 but noway... the blue led start to flash very fast but no sign on life...
i use:
baud rate 57600
data bits 8
parity none
stop 1
lbendlin
PostPosted: Sun Aug 15, 2004 11:12 pm    Post subject: Reply with quote
One problem on the 3970 is that most COM ports are already occupied (by BlueTooth and by the CIR infrared as well as the standard infrared. The jacket may have placed itself on COM0: - something that not many programs understand or include.
Can you try to move some of your ports around? For example the BT Manager alows you to manipulate the incoming and outgoing BT serial ports.
Lutz
zanusso
PostPosted: Mon Aug 16, 2004 8:56 am    Post subject: Reply with quote
in fact the com port used by the GPS Info1.3 is COM0 ... but i don't know how to move ore change the settings ... please helpme
lbendlin
PostPosted: Mon Aug 16, 2004 9:09 pm    Post subject: Reply with quote
There is a utility available from Franson Technologies (the makers of GPSGate) that allows to enable/disable physical ports on your machine. But this is definitely something you do at your own risk...
http://franson.biz/forum/topic.asp?TOPIC_ID=18
Lutz
zanusso
PostPosted: Mon Aug 16, 2004 10:19 pm    Post subject: Reply with quote
Thanks very much... you solve my problems... now everythings works on com5.
you are greate
22.044 (24 Apr 24)
