Pocket GPS World :: View topic - i3 re-routing & batteries question?
larrens
PostPosted: Sun Mar 05, 2006 4:15 am    Post subject: i3 re-routing & batteries question? Reply with quote
I am confused about 2 things on the i3 Streetpilot. Please can someone clarify?
1) If I set up to go to a destination & en-route decide to turn off the suggested route (eg. because of heavy traffic), will it re-calculate & re-route me from the road I turned off?
2) If my car does not have a cig lighter, will it work soley on AA batteries? If so, what are the batteries actually for?
Nickwolf
PostPosted: Sun Mar 05, 2006 8:29 am    Post subject: Reply with quote
Yes it will recalculate your route, you can also select detour from the menu which will cause it to try a different way.
Yes it will work on batteries without any external power supply.
Nick.
paulhgc
PostPosted: Sun Mar 05, 2006 10:17 am    Post subject: Reply with quote
get some nimh rechargeable batteries and if you use 2 and keep 2 in your pocket they will easily last you 2 days
larrens
PostPosted: Sun Mar 05, 2006 10:33 am    Post subject: Reply with quote
Thanks.
Does that mean that on a day to day basis, if it is being used in a car with a cig lighter, one does not need the batteries, or do they play a role with the cig lighter power?
ride4smilesjonny
PostPosted: Sun Mar 05, 2006 10:37 am    Post subject: Reply with quote
larrens wrote:
Thanks.
Correct, as long as a cig lighter is available then you do not need AA batts, if you wanted to stick it on your mountain bike which has no power source then you can insert the AA batts. -
Also - just to clarify, if you stop the routing, then decide five miles down the road you want to resume then it will resume from your new location, not the one five miles previous where you paused it! :D
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-)
larrens
PostPosted: Sun Mar 05, 2006 11:07 am    Post subject: Reply with quote
But, if I don't "pause" the unit but simply turn off the route to avoid traffic, it will start recalcing a new route from where I turned off - is that correct?
Almahadeus
PostPosted: Sun Mar 05, 2006 12:51 pm    Post subject: Reply with quote
100% correct.
PaulB2005
PostPosted: Sun Mar 05, 2006 2:58 pm    Post subject: Reply with quote
Back to batteries.
Keeping batteries in the unit when switched off will reduce the amount of time needed to Acquire the Satellites (typically under 15 seconds)when you switch back on again compared to a few minutes.
Aitch2
PostPosted: Sun Mar 05, 2006 3:47 pm    Post subject: Reply with quote
Also - setting the correct battery type 'Alkaline or Nimh' will ensure that the remaining battery life is correctly reported.
Aitch
Find Somewhere Else 090407: www.marillion.com
PaulB2005
PostPosted: Sun Mar 05, 2006 8:11 pm    Post subject: Reply with quote
Well, slightly less inaccurately. Mine still cuts out shortly after going down to 2 bars. 2500 mAh Uniross.
