Pocket GPS World :: View topic - Length of name of POI files
TonyD
PostPosted: Sat Mar 04, 2006 6:06 pm    Post subject: Length of name of POI files Reply with quote
Is there any chance of shortening the file names from "pocketgps uk gatso" etc. to something that would enable TT to display the latter half of the name. Mine all display as pocketgps UK ... rendering it very difficult to work out which is which. I know the icons are different and if you select one you see a bit more - but you know what I mean.
PostPosted: Sat Mar 04, 2006 6:26 pm    Post subject: Reply with quote
Tony switch the device to landscape mode first - then configure the warnings you should see the full name displayed then, copywrite is the most probable reason for the name, also if they are renamed it would cause havoc with duplicate POI cats for a large number of people, even exceeding the 39 POI limit when the re-named files were downloaded if using the speed zoned set-up - Mike
Pocketgps
PostPosted: Sat Mar 04, 2006 8:05 pm    Post subject: Reply with quote
I have always renamed mine to just gatso.ov2 etc., only takes seconds.
22.054 (22 May 24)
