Pocket GPS World :: View topic - lost poi warnings on turn off tt5
Cupra-Matt
PostPosted: Sat Feb 18, 2006 3:05 pm    Post subject: lost poi warnings on turn off tt5 Reply with quote
Q1...Some of the speed camera locations in my pda tt5, have a red square as the image instaed of the camera or limit sign as with most.
Is there a way of changing the symbol to match with the other cameras?
Q2...Also with these warnings, seem to be mainly on specs cameras if it helps, every time i reboot or turn power off to my pda ie;end of journey etc.
I turn back on to travel again and i have to reset the poi warnings to give any kind of alarm.
thanks in advance matt, excuse me for being new to all this
PostPosted: Sat Feb 18, 2006 4:11 pm    Post subject: Reply with quote
Its sounds like you have loaded too many POI's there is a limit of 39 user configurable POI's that can be loaded, if you are running the full speed zoned set up then you will have used up 24 of these available ones, try removing some of the other POI's you have put onto the device. The red squares are usually caused by an ov2 file being present but no coresponding bmp for the unit to display, for each POI you must have an ov2 file (the positional data) and the bmp for the unit to display - Mike
22.053 (15 May 24)
