Pocket GPS World :: View topic - Locking SD...?
Locking SD...?
fLaMePr0oF
PostPosted: Thu Feb 09, 2006 9:55 pm    Post subject: Locking SD...? Reply with quote
You list the unit not 'locking' into the SD slot as a 'con' in your review, however, although I don't have one of these units, I'm certain that it will lock just as all other SD / MMC cards do; the standard is designed so that you have to 'push and click' to both inset and release a card...
It seems likely to me that there may be a problem with your PDA, either the locking mechanism in your SD slot doesn't work or perhaps it's just not particularly well built, however, in my experiance these cards lock pretty firmly into place on most well built systems, the only exception I've found to this is the cheap multi card reader I sometimes use which has no locking mechanism for SD / MMC cards - perhaps your PDA has a similarly cheap / poor mechanism?
((¸¸. ·´ .. ·´ steve-MARTIN-:¦:-
lbendlin
PostPosted: Fri Feb 10, 2006 12:33 am    Post subject: Reply with quote
you don't have to push and click to eject the card - you can simply pull it out. The push-click is just done to give you a better grip with cards that are flush. If the card extrudes - like the GPS card - then you can very quickly pull it out accidentially. Because there is no locking mechanism in SD cards by design.
Lutz
TomTom/TeleAtlas NAVTEQ
22.053 (15 May 24)
