Pocket GPS World :: View topic - HELP WITH INSTALLING THE POI SOFTWARE ON THE TOMTOM 300
jizzler
PostPosted: Wed Feb 01, 2006 1:25 pm    Post subject: HELP WITH INSTALLING THE POI SOFTWARE ON THE TOMTOM 300 Reply with quote
8O 8O [b][b] great site guys and sorry to be a pain but i have a problem activateing the poi sofware on my tomtom300, i have done all the things suggested and it shows up on my menu screen but i am not sure or dont know how to use it or if i have done it properly. could someone please post a idiots guide on how to use and install it so that i know i am doing everything correctly thank you. Embarassed :oops
Privateer
PostPosted: Wed Feb 01, 2006 1:33 pm    Post subject: Reply with quote
Hi jizzler,
There are some guides that should be read (in the following order):
Arrow The beginner’s guide to the PocketGPSWorld camera database.
This explains about the different camera types and about categories and subcategories, so that you can decide how you want the database on your unit.
Depending on whether you have TomTom Navigator on a Pocket PC or TomTom GO, please read either:
Arrow How to install (camera database) POIs to TomTom Navigator 5.
This guide explains how to load the PocketGPSWorld camera database onto a Pocket PC running TomTom Navigator 5.
Arrow How to install (camera database) POIs onto a TomTom GO, Rider, or One.
This guide explains how to load the PocketGPSWorld camera database onto your TomTom GO, Rider, or One.
Once you have installed, set up, and used the PocketGPSWorld camera database for a while on your TomTom SatNav system. You may want to share and send in details of cameras yourself. You can do this by using the PocketGPSWorld POI Capture utility:
Arrow The PocketGPSWorld POI Capture utility.
You do not need the PocketGPSWorld POI Capture utility on your TomTom SatNav system in order to use the PocketGPSWorld camera database. However if you want to send in camera details then POI Capture makes the process of recording cameras much easier on TomTom Navigator and GO (original, 300, 500, and 700). At the moment POI Capture will not work with TomTom Rider, One, and mobile. This is for a technical reason, which we hope, will soon be rectified by TomTom.
The above guides may look lengthy and complicated when first seen. However if you grab a cup of coffee and read each one thoroughly then they should make sense as they have been written in a step-by-step way, for ease of reading.
Robert.
Garmin Camper 770 LMT-D
jizzler
PostPosted: Wed Feb 01, 2006 5:53 pm    Post subject: sorry still no good. Reply with quote
Embarassed i have done all that is listed but i have no more memory space left in my map of great britain and so i cant put the poi capture software into that folder. i have the poi capture and quick camera add on page 4 of my tomtom not page one as you have described, and when pressed neither works please can someone tell me where i have gone wrong. :D
Privateer
PostPosted: Wed Feb 01, 2006 6:32 pm    Post subject: Re: HELP WITH INSTALLING THE POI SOFTWARE ON THE TOMTOM 300 Reply with quote
Hi jizzler,
Are you trying to install/use the PocketGPSWorld camera database or the POI Capture software? If you want to use the camera database, you don't need to install the POI Capture software, which is used for recording camera details and not detecting cameras.
If you have the original TomTom SD card (128Mb) then it would be a good idea to get a new one that is at least 256Mb or even 1Gb if you think that you might want to add extra maps. You then use a card reader to copy the entire contents from the old SD card to the new one.
Robert.
jizzler
PostPosted: Wed Feb 01, 2006 6:38 pm    Post subject: HI!!!!!!!!!! Reply with quote
yes sorry i am and have been useing the camera datebase for a few months now and with no problems, its the capture software i am having problems with. i will get a bigger card and try again thanks.
Privateer
PostPosted: Wed Feb 01, 2006 6:46 pm    Post subject: Reply with quote
POI Capture should go into its own folder (off the root directory) called "/POICapture". Please see here for further information.
You also need to be running version 5.202.
Robert.
22.055 (29 May 24)
