Pocket GPS World :: View topic - speed cameras on a tt go 300
roadnobler
PostPosted: Mon Jan 09, 2006 6:14 pm    Post subject: speed cameras on a tt go 300 Reply with quote
just got a new computer with several card readers built in,including one for sd cards.Question can I use this to put the speed cameras onto a tt go 300,instead of doing it with actual go unit unit attached to the computer?
gazza1
PostPosted: Mon Jan 09, 2006 6:30 pm    Post subject: Reply with quote
Simple answer YES. Just take the SD card out and stick it in the card reader. Then you can transfer the files to it. Just remember to do an EJECT before removing the card.
PostPosted: Mon Jan 09, 2006 7:55 pm    Post subject: Reply with quote
Good point from Gazza...
Apparently the copying process to the SD card sometimes is still going on, even though it LOOKS like it has finished. If you use the "Safely remove hardware" icon in the system tray (bottom right of your PC screen) it should finish properly first.
Just to clarify, it should make no difference whether you connect the Go via USB, or put the card into a card reader. Either way, the PC should recognise it as another hard drive on your system and show it to you in Explorer or My Computer.
22.052 (08 May 24)
