Pocket GPS World :: View topic - Tom Tom One - blank screen stopped working
Nick101
PostPosted: Mon Dec 26, 2005 5:57 pm    Post subject: Tom Tom One - blank screen stopped working Reply with quote
Just got my Tom Tom One from Santa. Was working great yesterday, then today did the software upgrade to 5.420, all seemed fine. Tom Tom was showing my home address, I was reading the instructions to down load the camera POI, looked back at my Tom Tom to find it was powered off and blank. Tried to charge via the car charger, it shows charging but still won't turn on, any one ese had this problem?
notorious19
PostPosted: Mon Dec 26, 2005 6:23 pm    Post subject: Reply with quote
same kinda thing happened to me after i did the camera poi ,i had to do reset and it was fine but took the cameras off again after
sgould
PostPosted: Mon Dec 26, 2005 6:34 pm    Post subject: Reply with quote
You may need to make a bit of room on the card. Try removing any foreign voices you don't need.
Make a full back up to your PC before doing any changes.
Better still, copy your backup to a bigger blank SD card and use that as you day to day card.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Nick101
PostPosted: Mon Dec 26, 2005 6:41 pm    Post subject: Reply with quote
thanks, I reset it and it seems fine now. Now all I have to do is down load the camera POI from this site...will try later, thanks again
mossman
PostPosted: Mon Dec 26, 2005 7:14 pm    Post subject: Reply with quote
I would certainly recommend buying an additional, larger (256meg) card for the UK maps, copy the supplied card over and use the larger one as your day to day card. Plenty of free space then for all the additional bits that I'm sure you'll want to put on.
PostPosted: Tue Dec 27, 2005 4:51 pm    Post subject: Reply with quote
Nick101: Even if it's working OK now, you might find it crashing when it's calculating routes unless you do whet sgould suggested:
That's an easy first fix, if you don't want to get a bigger card yet.
Nick101
PostPosted: Tue Dec 27, 2005 7:18 pm    Post subject: Andy: Reply with quote
Thanks for the tip, I removed one voice, I only had two on it. Any way pleased to confirm the camera poi from this site are working ace and it seems fine.
cheers
woodlands40
PostPosted: Wed Dec 28, 2005 4:43 pm    Post subject: Reply with quote
I had the same problem. Charged my One overnight, used it the next day after adding the cam poi and a new voice. I used it untill the battery was flat then recharged it. It would not switch on untill i reset it with the trusty pin kept for the washer jets. No problems since then.
