Big_Kev Occasional Visitor
Posted: Tue Jan 10, 2006 12:44 pm Post subject: Help with TomTom 5 and XDA2i...please. |
Dear all,
I've been a user of TT5 and XDA2 for a while with no problems. I've now replaced the XDA2 with an XDA2i and cannot get TT5 to work at all. It installs fine and I can pair the bluetooth GPS receiver (BT device) ok but I do not pick up a GPS signal.
I've tried all the COM ports and none work. I've also tested the receiever on another XDA2 and it works ok. I've removed O2 Active and disabled incoming beams.
Please can anyone help? Thanks. |
Posted: Tue Jan 10, 2006 1:19 pm Post subject: |
Kev, welcome, in TT go to the GPS page, top RH does the blue/ yellow disk spin, if so if is receiving data, if not then the com ports are wrong, also try setting it as other cabled NMEA device, set the baud speed then select the BT com port (I think its com6); to see the number put the device into landscape mode first, it just makes it easier. Once the disk is spinning take it all outside and wait, it could take 15 mins for the first fix - Mike |
Posted: Tue Jan 10, 2006 3:49 pm Post subject: |
Hi Mike,
Thanks for the quick response.
You're a star - works like a charm.
Kev. |
brianleach Occasional Visitor
Joined: Sep 06, 2004 Posts: 36 Location: Winchester, Hants
Posted: Fri Jan 13, 2006 1:44 pm Post subject: Help with TomTom 5 and XDA2i...please. |
Brilliant.
This also works with an xda II.
Solved a problem I've had for a while.
Thanks.
Brian |
