mark.peters Occasional Visitor
Posted: Sun Sep 14, 2003 8:04 am Post subject: Ipaq / TTN2 & SD cards |
Anyone else using the above combo ?
Getting no end of problems with mu Ipaq now refusing to recognise the Sandisk SD card that I have !
Got a work colleague who has the same set-up and his has also gone t*ts up as well ... he's using 'Pretec' & 'KingMax' SD cards !
HP have advised me to do a hard reset - which apart from clearing my machine of all installed software - done nothing else ! Still got the same problem !
Mark |
Dave Frequent Visitor
There are known issues with specific SD cards for compatibility issues, Sandisk appear to be one of the more problematic cards. I use Integral which are pretty good on the iPAQ's.
I have had the problem before where a card has been working perfectly okay for months on end, then suddenly it stops working but put it into other iPAQ's or card readers and it's fine, and a hard reset has cured the problem. Sometime's the Pocket PC's can get to a stage where they're completely confused and won't recognise insertion of any SD cards. Only recourse at this stage is to hard reset. |
gstenson Frequent Visitor
Joined: 23/10/2002 09:53:59 Posts: 267 Location: Lincolnshire, UK
check your firmware version of your PPC, sometimes causes problems with SD cards. I found that my Sandisk card went like this...I emailed Sandisk and they offered to replace it via the warranty. Not bad considering I bought it on eBay |
minesapint Occasional Visitor
Joined: 19/04/2003 22:42:21 Posts: 41 Location: United Kingdom bucks
if its the 3970 or 3975
there is a sd card driver update
try looking at
http//h18007.www1.hp.com/support/files/handheldiPAQ/us/locate/71_4704.html |
DavidW Pocket GPS Moderator
An equivalent update has been produced for the 3950/3955 running ROM 1.11 - which contains the same flawed SD drivers.
Download that one here.
Make sure you pick the right upgrade for your hardware - 395x or 397x and that you have the right ROM version installed before following the other instructions.
David |
Neverlost Occasional Visitor
Joined: 10/01/2003 09:32:10 Posts: 13 Location: United Kingdom
Had a similar problem in that the SD card was OK for a month or so before becoming unrecognised. Returned the IPAQ 3970 to HP, they replaced the motherboard FOC. Apparently there are some units out there with a known hardware defect.
Unit now works 100% for over 6 weeks. |
