Pocket GPS World :: View topic - unknown card in socket 2
rob-bob
PostPosted: Mon Jan 05, 2004 7:44 pm    Post subject: unknown card in socket 2 Reply with quote
keep getting unrecognized card
and in the box unknown card in socket 2
any help please
any thanks
Rob
PostPosted: Mon Jan 05, 2004 7:51 pm    Post subject: Reply with quote
I can guess this is a Navman GPS Jacket but what software are you using?
rob-bob
PostPosted: Mon Jan 05, 2004 11:13 pm    Post subject: software Reply with quote
i am using tom tom
PostPosted: Tue Jan 06, 2004 9:30 am    Post subject: Reply with quote
Is TomTom working OK? This normally suggests that the Navman Serial Driver is not correctly installed but usually this would then result in a non-functioning GPS?
You can download the driver here. In TomTom 1 they provided native support for the Navman Jackets. From Version 2 they chose not to, if you had upgraded from v1 then all was fine as the jacket driver was carried over in the upgrade. Fresh installations of TomTom2 require the installation of the Navman Serial Driver in order to use Navman GPS Jackets.
JonR
PostPosted: Fri Jan 09, 2004 4:27 pm    Post subject: Reply with quote
Is this dependant on tomtom. I have the same problem, and it appears when I attach the sleeve, before I start any SW.
PostPosted: Fri Jan 09, 2004 10:15 pm    Post subject: Reply with quote
Not just TomTom, any app that needs to 'talk' to the Navman Sleeve should have this driver installed.
JonR
PostPosted: Sat Jan 10, 2004 11:43 pm    Post subject: Reply with quote
I have the 3.1.6 driver installed (and re-installed), but it did not solve my problem. But it is not alsways I get the socket error message, this is very unpredictable, sometimes it works fine.
Any other hints?? Did the 3.1.6 solve your problem entirely and consequently??
PostPosted: Sun Jan 11, 2004 10:39 am    Post subject: Reply with quote
Is yours a Navman Sleeve or one of the HP iPAQ Navigation or CoPilot sleeves?
JonR
PostPosted: Sun Jan 11, 2004 11:55 am    Post subject: Reply with quote
Navman sleeve bought bundled with Maptech Pocket Navigator, as follows:
Navman 3000 Sleeve version is 2.1.0R01264 BW A, Navman 2.0.0
iPAQ Rom version is 1.11.19 ENG of 24th May 2003
The problem has actually been discussed earlier (but slightly mixed with the TTFF problem, which I don't have), without any solution for me:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=4708&sid=d13f9b1ca13e8a5aa5aaff4ca37a3409
unixciscosun
PostPosted: Fri Feb 17, 2006 2:09 am    Post subject: navman 3450 coplit edition Reply with quote
will this work with teh smart st software. I get an error that the card is unreonized in slot 2 i have a ipaq 3835
