Pocket GPS World :: View topic - ScaredyCats Apps Re: Quick Add Camera
Goto page 1, 2, 3, 4  Next
jimbokb
PostPosted: Mon Sep 26, 2005 11:33 pm    Post subject: ScaredyCats Apps Re: Quick Add Camera Reply with quote
I recently installed Scaredcats Apps v5.202 plus apps on my 300. but have being quite a lot of bother and have decided to just use the Quick Add Camera and remove the rest.
My problem is that Quick Add is on page 4 and I want it on page 1.
I managed to get it to move to page 1 but when I go back to page 4 I now have 4 Quick Add cams. what on earth is going on.
TTG 300,External Aerial
1Gig Viking SD, 512 Viking SD(Backup)Nokia 6680 (o2), 512 MMC
Map Great Britain v 562 App v 6.150 , GPS v 1.21 Boot 4.29, OS:1221
PostPosted: Tue Sep 27, 2005 7:24 am    Post subject: Reply with quote
Did you delete the unused apps themselves from the catapps folder?
Did you remove the Task_SDKx lines from Page 4 of the .mnu file?
jimbokb
PostPosted: Tue Sep 27, 2005 12:12 pm    Post subject: Reply with quote
I have sent MMU as requested.
By the way which are you using v5.201 or v5.202, on here you show 5.202 but on mytomtom forum you show 5.201
Thanks for your help.
jimbokb
PostPosted: Sun Oct 02, 2005 5:09 pm    Post subject: MMU file under 5.202 Reply with quote
Can someone please help me sort this mmu file out.
No matter what file I move Tomtom just shows the same order.
All I want Is favourites moved to Menu Page 4 & SDK 1 moved to Menu Page 1.
I and a few other people have tried this but whatever Menu Item we move the unit still shows the Add Cam on page 4 and Add Favourite on page 1, what am I doing wrong.
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Main Menu 1 of 4|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_DELETE_ROUTE|
MENUITEM|TASK_SDK1|
MENUITEM|TASK_MENU_PREFERENCES|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Main Menu 2 of 4|
MENUITEM|TASK_MENU_PLAN_ATOB|
MENUITEM|TASK_SHOW_MAP|
MENUITEM|TASK_MENU_ROUTE_INSTRUCTIONS|
MENUITEM|TASK_MENU_PHONE|
MENUITEM|TASK_ITINERARY|
MENUITEM|TASK_PAGE3|
MENUPAGE|TASK_PAGE3|Main Menu 3 of 4|
MENUITEM|TASK_SHOW_WEATHER|
MENUITEM|TASK_MENU_DOWNLOAD|
MENUITEM|TASK_MENU_TRAFFIC|
MENUITEM|TASK_TUTORIAL|
MENUITEM|TASK_SHOW_GPS_STATUS|
MENUITEM|TASK_PAGE4|
MENUPAGE|TASK_PAGE4|Main Menu 4 of 4|
MENUITEM|TASK_ADD_FAVORITE|
MENUITEM|TASK_PAGE1|
DeeSee
PostPosted: Mon Oct 03, 2005 3:24 pm    Post subject: Reply with quote
Hello Jimbokb,
You seem to be having no end of problems with this.
There is nothing wrong with your tomtom.mnu file so leave as is until you have a working system. Then you can move stuff around to your heart's content.
Make sure you have created an SdkRegistry folder in your 300s root and that tomtom.mnu is placed in it (Note: Linux is case sensitive). There should also be quickam.bmp and quickam.cap in the SdkRegistry folder.
You should also have the folder catapps in root and quickam should be in there.
Hope this helps.
DeeSee
DeeSee
PostPosted: Mon Oct 03, 2005 3:34 pm    Post subject: Reply with quote
Another thought:
I notice that you keep mentioning MMU when referring to the TomTom menu file.
This file is called tomtom.MNU (my upper case for emphasis - It should be lower case).
If you have been calling it MMU the TomTom won't read it and will default to its normal inbuilt menu but will add any SDKs to the end of the menu giving you what you are seeing.
DeeSee
worthingsaxovtr
PostPosted: Mon Oct 03, 2005 4:49 pm    Post subject: Reply with quote
I have been thinking about adding this so I could mark the position of cameras, but after reading all of thew replies dont think I will bother, as it makes no sense,
sorry for being dim
sparkey
PostPosted: Mon Oct 03, 2005 7:00 pm    Post subject: Reply with quote
I had a bit of trouble with this program got it working now it is a very good. I have already sent my camera i spotted to pocketgpsworld so i have been told it was later for this months but will be in next Laughing
sparkey
PostPosted: Mon Oct 03, 2005 7:03 pm    Post subject: Reply with quote
Have a look in the file you downloaded 5.202 and see if there is a data.chk in there.AND look in your sd root file and see if you got another one in there,sounds like the same thing i done Embarassed
sparkey
PostPosted: Mon Oct 03, 2005 7:04 pm    Post subject: Reply with quote
Sorry btw if you dl 5.202 you would have 6 pages not 4 like you have listed
PostPosted: Mon Oct 03, 2005 7:17 pm    Post subject: Reply with quote
You can modify the original mnu file to suit yourself. On my Classic I only use 2 pages, it makes it very snappy.
jimbokb
PostPosted: Mon Oct 03, 2005 10:23 pm    Post subject: Reply with quote
As spotted by many and not by me Grrrr I had renamed the file MMU instaed of MNU which I have now changed, however I still have the problem with the phone icon which I am sure is something to do with the new MNU file.
Why is the incorect phone icon showing.
Privateer
PostPosted: Mon Oct 03, 2005 11:26 pm    Post subject: Reply with quote
Hi jimbokb,
jimbokb wrote:
However I still have the problem with the phone icon which I am sure is something to do with the new MNU file.
Do you mean the "call number"? If you do you need to edit the tomtom.mnu with MS Notepad and add the "call number" function. The code you use is:
Code:
TASK_DIAL_POI
Have a look at this thread for further information.
Robert.
Garmin Camper 770 LMT-D
jimbokb
PostPosted: Tue Oct 04, 2005 11:48 am    Post subject: Reply with quote
Not quite sure where to put this command, do I replace MENUITEM|TASK_MENU_PHONE|
with
TASK_DIAL_POI
jimbokb
PostPosted: Tue Oct 04, 2005 11:59 am    Post subject: Reply with quote
Many thanks to Privateer I just added the command at the end of the MNU file and I have the Connect To Phone option again and the other grayed out one has gone.
Its been a long hard slog but worth it in the end.
Many thanks to Andy who really spent a lot of time on helping me out and of course Privateer who got the bit that was bugging me.
Thanks to all who helped me.
Page 1 of 4
22.051 (01 May 24)
