Pocket GPS World :: View topic - Go Maps update on SD card...how to install to old card?
Boxbrownie
PostPosted: Thu Nov 17, 2005 7:22 pm    Post subject: Go Maps update on SD card...how to install to old card? Reply with quote
Hello, I recieved today my map update for my TTGo....but there are no instructions at all for installing the new maps etc onto an exsiting SD card, obviously I want to keep my larger card with europe maps and install the newer GB maps frpm the update, can I just copy and paste the map folder or is there an install procedure I must go through?
BTW I have already upgraded to version 5.420
Best regards David
PostPosted: Thu Nov 17, 2005 7:48 pm    Post subject: Reply with quote
You can remove the old map folder (remember to save your POI's first) and just copy the map folder from one sd card to the other.
You will need to activate the map as, at this stage, the program doesn't know about it. Also do a backup of the new card to the PC. Just in case.
Boxbrownie
PostPosted: Thu Nov 17, 2005 7:52 pm    Post subject: Reply with quote
Thanks Richard, but I have just opened both cards and the new GB maps folder is almost twice the size of the old GB maps! So I will need to get a 1 gig card to be able to install the new GB maps with my Europe maps as well.......
Nothing ever goes that smooth, does it? Laughing Out Loud
BTW...I did expect a CD rom from TomTom not the SD card I received.
Best regards David
Boxbrownie
PostPosted: Thu Nov 17, 2005 7:57 pm    Post subject: Reply with quote
Another quick question Richard, I noticed on the new card there are several new folders, do I need to copy any of these over or just the maps folder?
I was afraid that if I missed a particular folder maybe something might not work!
Best regards David
PostPosted: Thu Nov 17, 2005 8:10 pm    Post subject: Reply with quote
On mine I have 4 Folders. Map, itn,zip and TomTom-cfg.
I can't remember now how many there were on the original, probably only the map and tomtom_cfg.
I would copy all the SD card to the bigger card and then upgrade to 5.42 again.
You say the Map Folder is a lot bigger. It could be that you have the GB-Plus map.
Boxbrownie
PostPosted: Thu Nov 17, 2005 8:38 pm    Post subject: Reply with quote
It does indeed say GB plus......what is the difference?
PostPosted: Thu Nov 17, 2005 8:42 pm    Post subject: Reply with quote
It's the intergrated Major Roads of Europe. With the Classic it came as an additional file to the GB Map.
You can therefore navigate through Europe on the major roads, and in GB at street level, without switching maps.
Boxbrownie
PostPosted: Thu Nov 17, 2005 9:01 pm    Post subject: Reply with quote
That makes a lot of sense......of course! DOH!!!!!!!!!
Now to hunt down a bigger card this weekend I suppose?
Cheers Richard, once again Pocket GPS to the rescue.
Best regards David
