Pocket GPS World :: View topic - HAVE YOU HAD ANY PROBLEMS SINCE UPGRADING TO Ver2.7 SOFTWARE
Logan1475
PostPosted: Fri Nov 04, 2005 3:42 pm    Post subject: Reply with quote
Upgraded to V2.70 a couple of days ago and seems to be ok. Have done about 200 miles and no major problems.
Did think I had a problem with icons disapearing, but I think from reading on the forum that this is normal and I perhaps just had things set up not quite right. Confused See 'Disapearing icons' thread.
Totally unlrelated -Thank god its Friday Guinness
Mr_Gonzales
PostPosted: Fri Nov 04, 2005 11:03 pm    Post subject: Reply with quote
No problems at all, if anything the redraw seems faster when zooming in and out. It used to take longer with 2.5 and 2.6, I thought.
LucyAkhurst
PostPosted: Fri Nov 04, 2005 11:52 pm    Post subject: Mostly fine Reply with quote
the update was mostly ok. no crashes so far.
There is more beeping and boinging than before though !
Lucy
Bob_M
PostPosted: Sat Nov 05, 2005 9:38 pm    Post subject: Reply with quote
I thought that the I3 was a little sluggish when running 2.7. I went
"off route" a couple of times and it seemed to take a while to notice.
There were no system crashes or power downs that a couple of others have had.
I've reverted back to 2.5 and I do think it's faster.
Bob_M
PostPosted: Mon Nov 07, 2005 6:35 pm    Post subject: Reply with quote
no problems with 2.70. just got back from 4 days in blackpool and surrounding area.
LT
PostPosted: Mon Nov 07, 2005 11:11 pm    Post subject: Reply with quote
No problems for me either. Have to say I was scared to death as it started to download bearing in mind it appears to delete the original software first, my thoughts were, if it stops now, I'm in the Sh*t!
Got all the POI's on and speed cameras seem to bong and bong more if you're over the speed limit, and the camera location icon shows up if you're over the speed limit.
zogman
PostPosted: Tue Nov 08, 2005 10:36 am    Post subject: Reply with quote
like you crazylegs i found the i3 much slower in caculating and re-drawing screens...i'm sticking to v2.5 which seems the most quickest and stable..
JonA
PostPosted: Wed Nov 09, 2005 12:26 pm    Post subject: Reply with quote
Tried updating to v2.7 Like others, seems much slower in redrawing the map and calculating routes. Also seems to do several rout recalculations at times.
When switched on, seems a little slower at acquiring satellites.
Have gone back to v2.5 for now.
zogman
PostPosted: Wed Nov 09, 2005 1:40 pm    Post subject: Reply with quote
to go back to v2.5 just download version 2.5 like you did with v2.70 when you upgarded...now finding v2.50 might proove a little more difficult but i'm sure its in one of these threads somewhere.
HySeeker
PostPosted: Mon Nov 14, 2005 12:27 am    Post subject: Reply with quote
I have been using 2.7 for about a week now, cannot say I noticed any difference in recalc or redraw times[/quote]
Bob_M
PostPosted: Mon Nov 14, 2005 7:24 pm    Post subject: Reply with quote
I thought I'd give 2.7 another go. It's been fine, no problems at all.
When I tried it before we were having even worse weather than usual in Scotland, it may have been the really thick cloud cover having an effect on signal reception.
Bob_M
