Pocket GPS World :: View topic - help BT77GPS and IPAQ2210
Trishaxolotl
PostPosted: Mon Oct 31, 2005 7:18 pm    Post subject: help BT77GPS and IPAQ2210 Reply with quote
I have just purchased a 2nd hand HP IPaq 2210 with what I beleive is a BT77 bluetooth GPS and TOMTOM5.
I can pair up with GPS and it flashes away but if I check connection status it says connected but no bytes received or sent. Signal strength comes up blue - just right.
In Bluetooth active connections I get outgoing connections : BT GPS SPP Slave and Incoming connections : nothing.
It also drops the connection after about 1-2 mins.
When you open tomtom it says no GPS device!
I am assured this worked before it was posted.
Do I need to know configuration instructions - what are they?
Should there be an instruction manual or software disk?
Can anyone HELP?! Crying or Very sad
PostPosted: Mon Oct 31, 2005 10:03 pm    Post subject: Reply with quote
Select other wired NMEA device in the gps set-up screen, put in the correct baud speed for your device and on the final screen select the bluetooth com port - mike
22.054 (22 May 24)
