Pocket GPS World :: View topic - It won't fit!!!
It won't fit!!!
rcflyers
PostPosted: Sat Oct 15, 2005 8:52 am    Post subject: It won't fit!!! Reply with quote
I have tried installing TomTom 5 onto the 256Mb memory card in my Mitac Mio 168, the program installs and runs fine (I have no maps loaded at this point) When I copy the Great Britain map to the memory card It runs out of space.
What am I doing wrong?
Should I install TomTom on the PDA's memory and leave more room on the SD card for the map?
Thanks.
PostPosted: Sat Oct 15, 2005 9:14 am    Post subject: Reply with quote
It should easily fit into 256, have you got other stuff on there already?
rcflyers
PostPosted: Sat Oct 15, 2005 9:42 am    Post subject: Reply with quote
No, I wiped the card clean before I started and hard reset the PDA.
PostPosted: Sat Oct 15, 2005 9:50 am    Post subject: Reply with quote
I'm not sure how much space the app consumes if installed on a memory card (the GP Map is a little over 100MB).
You could either remove some of the unneccessary voices or install to main memory and install just the map to the storage card.
rcflyers
PostPosted: Sat Oct 15, 2005 10:04 am    Post subject: Reply with quote
My GB Plus map folder is 198Mb
PostPosted: Sat Oct 15, 2005 10:12 am    Post subject: Reply with quote
Ah Plus Map, indeed that is much larger. Install the application to main memory and only the map to storage card then.
rcflyers
PostPosted: Sat Oct 15, 2005 11:59 am    Post subject: Reply with quote
which folder shall I use on the pda's main memory?
Will It slow down other applications?
It only has 32Mb Ram.
PostPosted: Sat Oct 15, 2005 12:09 pm    Post subject: Reply with quote
You don't choose a folder, let the installer run and just select 'main memory' as the install location. I always install this way, if anything it'll run faster.
