Pocket GPS World :: View topic - Installing 5.1 upgrade
LeighB
PostPosted: Fri Oct 14, 2005 11:02 am    Post subject: Installing 5.1 upgrade Reply with quote
I have downloaded and hopefully installed the 5.1 upgrade to my Mio, however the install process seemed to stick, and I am unsure if it has proceeded correctly. TT5 seems to work ( at my desk anyway) but is there any way I can check the version number?
Leigh
Mio168 Kingston 256SD
TomTomNavigator3 3.07
TomTom Navigator 5
Memory Map 2004 OS 4.4
Checkpoint 2.02
PostPosted: Fri Oct 14, 2005 12:31 pm    Post subject: Reply with quote
To check which version you are running:
    Launch TomTom
    Select 'Change Preferences'
    Select 'Show Version'
If the App Version is 5.100 then the update has been installed successfully Smile
LeighB
PostPosted: Fri Oct 14, 2005 3:30 pm    Post subject: Reply with quote
Darren,
Thanks for your reply. The reason I can't find the version is that I have set up my own menu system, and the Show Version option is not there Embarassed
I guess I will have to run the menu program again to put it back?
Leigh
TomTom Navigator 5
Checkpoint 2.02
lupos0_1
PostPosted: Fri Oct 14, 2005 3:40 pm    Post subject: Reply with quote
No you don't. Start tomtom, then tap the bottom right corner (where it shows the satellites). The version number should show in the white box on the right hand side.
LeighB
PostPosted: Fri Oct 14, 2005 3:43 pm    Post subject: Reply with quote
Many thanks lupos0_1,
The upgrade obviously didn't work, it still shows verion 5.000
I will try and run it again, and come back if it still doesn't work properly.
Leigh
TomTom Navigator 5
Checkpoint 2.02
LeighB
PostPosted: Fri Oct 14, 2005 6:34 pm    Post subject: Reply with quote
I have tried rerunning the update, after restoring the backup I took before I first tried, and it still does not work.
I doubleclick the exe file, and get to a TomTomSetup screen, agree to the conditions, and click the forward arrow. The next screen shows files being transferred, but nothing then happens. The program will not close and I had to shut it down with Task Manager.
It seems to just lock up.
Any ideas?
Leigh
TomTom Navigator 5
Checkpoint 2.02
PostPosted: Fri Oct 14, 2005 6:45 pm    Post subject: Reply with quote
If you're using XP, you could try emptying the 'temp' folder in your profile.
    Click on Start, select Run and type %temp%, then press OK.
    Delete all the files in the Temp folder.
    Re-Run the upgrade.
Pocketgps
PostPosted: Fri Oct 14, 2005 6:53 pm    Post subject: Reply with quote
Download the ZIP file from TomTom's web site, that usually works OK, the .exe file seems to have these install issues.
LeighB
PostPosted: Fri Oct 14, 2005 6:54 pm    Post subject: Reply with quote
I will try the zip file route, hope that works
Leigh
TomTom Navigator 5
Checkpoint 2.02
LeighB
PostPosted: Sat Oct 15, 2005 11:55 am    Post subject: Reply with quote
Hi folks,
Thanks for your input, someone has removed the last few posts from this thread -- why??
Anyway I have tried both options suggested and neither works Sad
Empying the temp folder and rerunning the upgrade made no difference.
The zip file method did not even get as far as the TomTom Setup screen before locking up. Any thoughts?
Leigh
TomTom Navigator 5
Checkpoint 2.02
Pocketgps
PostPosted: Sat Oct 15, 2005 3:00 pm    Post subject: Reply with quote
LeighB wrote:
Hi folks,
The only thing I can suggest is a FULL backup of your current setup, then a hard reset, trying a clean install, if that does not work then at least you can revert back to your current setup via the backup you just made.
divxmontreal
PostPosted: Wed Oct 19, 2005 9:06 am    Post subject: Reply with quote
Check the following:
- Run the latest version of Active sync. I put the latest version here:
http://www.microsoft.com/windowsmobile/downloads/activesync38.mspx
- Put the partnership on guest in Active sync.
This should let you install the software.
Let me know if it worked.
Ciao for now
