dogo Occasional Visitor
Joined: 03/07/2003 17:50:59 Posts: 43 Location: United Kingdom
Posted: Sun Sep 14, 2003 8:04 am Post subject: TomTom GPS Hardware |
Hi can anyone tell me the meaning of the Flashing LED/Light on the GPS reciver. currently it flashes orange a lot! and then Flashes Green..
_________________ dogo |
RichDem Frequent Visitor
Joined: 12/12/2002 11:57:47 Posts: 259 Location: East Yorkshire
when it is flashing orange it is trying to get a fix, when it flashes once a second it has a 3d lock, when it flashes twice a second it only has a 2d lock.
Hope this helps
Richard |
cheers for the info! In that case i often get two green flashes per second , from time to time i do get one green flash...but i cant get TT2.2 to register the device... any ideas _________________ dogo |
DavidW Pocket GPS Moderator
Assuming you've selected the right serial port in the TomTom GPS driver (on almost all Pocket PCs, it should be COM1:), the right sort of GPS and the box next to those two settings on the second tab of the GPS driver contains a tick (if not, tap on it) - are you running a keyboard driver on your Pocket PC. If so, disable the keyboard driver.
Other possible solutions include a faulty cable or GPS, the cables not connected together correctly (not firmly located?), damaged serial port on the Pocket PC, or you've mistakenly connected an iPAQ 3800/3900/5000 series cable to an iPAQ 1910 (which won't work as the 1910 has no serial port).
David |
