Pocket GPS World :: View topic - Gatso 30, 50 ,or 70 notification with matching icon
kinggatso
PostPosted: Thu Sep 01, 2005 11:08 pm    Post subject: Gatso 30, 50 ,or 70 notification with matching icon Reply with quote
Sad
I am running TT5 and have downloaded the speed camera database from this site. Also I have added the alternate sound files from this site as well. However if I want to match the sound file 'gatso 30' there is no icon to suite, just a default one for gatso, mobile, spec, or red light. Is it possible to get the extra icons for 30, 50 ,70 etc, and does tt5 know the speed information of the cameras. If so could someone point me in the right direction. I am not using any other add-on like checkpoint etc, just tt5 at the moment. thanks!
PostPosted: Fri Sep 02, 2005 6:40 am    Post subject: Reply with quote
You must be using the basic 5 file camera set.
There can be 3 setups for speed cameras.
The first is a single file that contains all the cameras together, without any reference to what type. This is named pocketgps_uk_sc.ov2 and found in the 'single file version' folder.
Second is the 5 file version that divides the cameras into types. Gatso, Mobile, Specs, Redlight and Temporary. These you will find in the 'ov2 bmp' folder.
Third is the full 17 file version that divides the Gatso and Mobile files into speed zones. There are 7 each of the Gatso and Mobile files. These are found in the 'speed zoned/gatso/ov2 bmp' and speed zoned/mobile/ov2 bmp' folders. Add to these the Specs, Redlight and Temporary files as above.
I have not included the Continental file because you will only need this if going to the continent.. But should you want it , it's in the 'ov2 bmp' folder.
When you've decided which set you want copy each .ov2 file, and it's matching .bmp file to your map folder. Then setup the POI's in Manage POI.
To see cameras with a speed related icon, you need the 17 file version.
kinggatso
PostPosted: Fri Sep 02, 2005 10:29 am    Post subject: Reply with quote
:D thanks now sorted
22.052 (08 May 24)
