Pocket GPS World :: View topic - BLUETOOTH DUAL PAIRING
gill57
PostPosted: Fri Aug 26, 2005 3:24 pm    Post subject: BLUETOOTH DUAL PAIRING Reply with quote
Hi, :D
Can anyone tell me if there is a way that I can use my Nokia 3230 paired with both my bluetooth gps receiver and bluetooth nokia headset at the same time please Question .
with regards
gill57 Wink
aliendad
PostPosted: Fri Aug 26, 2005 3:33 pm    Post subject: Reply with quote
there is supposed to be a piece of software that can allow multiple conections, most mobile phones are designed for one item at a time.
also if you do get all three working together, so audio quality will be reduced
gill57
PostPosted: Fri Aug 26, 2005 3:37 pm    Post subject: Reply with quote
WOW Superfast reply or WHAT!!!
Do you know what this software is please Question
Foxhunter
PostPosted: Sun Aug 28, 2005 11:58 pm    Post subject: Reply with quote
Have you just gone ahead and tried it? I was told my Nokia 9500 'wouldn't support concurrent bluetooth connections' by Nokia and TomTom but actually it works just fine to listen to the voice instructions from Mobile 5 over the bluetooth headset without any tweaks at all.
gill57
PostPosted: Mon Aug 29, 2005 11:48 am    Post subject: Reply with quote
Jumping With Joy
Thanks for the answer Foxhunter. I have done as you said and it's absolutely perfect now thank you very much. I wish I had thought of it before posting but I am still a bit scared of breaking my phone.
:D :D :D
joe90
PostPosted: Tue Aug 30, 2005 5:26 pm    Post subject: Reply with quote
:D
My friend has just bought a Nokia 6680 and a Nokia HS 4W bluetooth headset. He is able to connect to TT Mobile 5 via an original TT bluetooth GPS (old type) and use his headset to send and receive calls. When the headset is active TomTom travel instructions are routed via the headset.
Despite the common belief that Nokia phones running TTM5 will not work concurrently with other bluetooth devices, it appears that certain combinations of nokia phones and bluetooth headsets will work.
Just wonder whether Nokia have addressed this issue with their latest models or is just good fortune that certain combinations work.? If so, it may be worth maintaining a list of compatible Nokia phones and brand of bluetooth headsets that enable concurrent connections.
gill57
PostPosted: Tue Aug 30, 2005 5:33 pm    Post subject: Reply with quote
I take back what I said about it being perfect. Just been on a long run today and the tt5 through the headset was quiter than the original phone audio. I had it set to the loudest on the headset HS-11W. Using it just for the phone is perfect but not both together unfortunately.
I am seriously thinking about a full hard wired car kit.
CJackel492
PostPosted: Wed Aug 31, 2005 9:21 am    Post subject: Reply with quote
There is a sequence in which to connect the devices to get 2 bluetooth connections to work,
On my 9500,
Start TomTom and start the GPS, allow them to connect,
Turn on the CarKit/headset,
Sound quality is an issue, but it's ok just for voice instructions,
Carl,
Phones - Nokia 9500 + a few others
Nokia 9500 running TTM5 Sad
View user's profile Send private message AIM Address
gill57
PostPosted: Wed Aug 31, 2005 1:42 pm    Post subject: Reply with quote
I have now started to use my system with a Visorcom bluetooth, I had it in the house and never used it (don't ask me why) anyway, I thought about it for a while then did as suggested previously, turned on the tt5 and gps let them connect, then connected the visorcom and hey presto!!!! sound is a lot better than my headset (Nokia HS-11W). I think I will probably sell the headset as I have only used it maybe three times at the most.
Thanks to all that commented. Hopefully I should be sorted. Hope this has helped others with the quiet tt5.
regards
22.053 (15 May 24)
