Pocket GPS World :: View topic - TT3 on hx4700
TT3 on hx4700
just_a_bloke
PostPosted: Thu Aug 18, 2005 3:04 pm    Post subject: TT3 on hx4700 Reply with quote
Hi folks can anyone help me out with this...
I have the TT3 wired solution using a PackardBell 3025
Yesterday I bought a hx4700 and installed TT3 on it.
The installation process noted that TT3 was intended for a previous version of Windows but appeared to install
This installation has (at least ) 2 issues
(1) No voices
(2) Can not connect to the GPS receiver
Do I need to get a new cable to connect the GPS to the hx4700 ( I used the one supplied for connection to the PackBell) ?
PostPosted: Thu Aug 18, 2005 9:25 pm    Post subject: Reply with quote
OK - welcome, check the volume level in the TT3 settings page and make sure you have selected a voice (Jane is the normal one), as for the GPS unit it must be compatable with the IPAQ, so a new cable is probably required, I would not recomend using one for a different unit as it could damage either the GPS or worse still the IPAq - Mike
just_a_bloke
PostPosted: Fri Aug 19, 2005 12:08 pm    Post subject: Reply with quote
Thanks for your advice , I'll re check the GPS reciever against the PackardBell to test if it still works - then I'll get cable for the iPaq ( or a new GPS module !
22.053 (15 May 24)
