Pocket GPS World :: View topic - Deleting "my saved items"
mistert
PostPosted: Sat Aug 13, 2005 12:26 pm    Post subject: Deleting "my saved items" Reply with quote
Hello,
I've only had my MapSonic v3.1/Zire 31 package for a few days and I am finding the software a bit fiddly.
Once I have added a saved item, it doesn't seem to be possible to delete or change it.Have I missed something or is this an oversight?
Also, every now and again if I do a complex long route it says its has run out of memory. Is this just a case of getting a bigger memory card?
Thanks.
martike
PostPosted: Sat Aug 13, 2005 8:20 pm    Post subject: Reply with quote
I can help you with your first problem.
The answer has been previously supplied by elan2s at
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=20176
I agree that it's a bit "fiddly", and 3.1 is supposed to be an improvement, but the real problem is lack of documentation, as you've found.
mistert
PostPosted: Sun Aug 14, 2005 7:43 pm    Post subject: Reply with quote
Thanks for that info, I got it working now, but only if I go to map mode, and ensure that the saved item is not a depart or arrive point, so that it shows up as a paper clip I can select and delete.
As for the other question, I answered it myself. When using a larger memory card it WILL use that extra capacity as memory when calculating more complex routes.
