Shaolyen Occasional Visitor
Posted: Wed Aug 03, 2005 11:14 pm Post subject: Driving in the English countryside with the Garmin Quest. |
I've had my Quest for a few months now, and for the most part I've enjoyed using it. But living out in the middle of nowhere has made me realise that there's a big flaw in the way the Quest works, and it's driving me up the wall (no pun intended).
Here's the problem. Out where I live there are plenty of big roads, but there are numerous tiny roads which connect villages and provide alternative routes to bigger towns. The problem is that these roads are just about the width of my rather small car, the sort which means you have to drive up onto the side if another car comes the other way. The Quest vastly overestimates the average speed possible on these roads, which can sometimes be as low as 10mph on the bendy bits... sometimes sending me off into the middle of nowhere when I know there's a much faster route elsewhere. (On a road which can support more than one car width.)
In MapSource, I've noticed that there are fields to enter your average speeds on certain types of road. Something like this would be great, but it just doesn't carry over to the Quest.
Does anyone know of a way to somehow lower the speed my Quest thinks I can drive on these roads, so it chooses the a faster route when possible? Please help, I'm desperate! |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Thu Aug 04, 2005 10:16 am Post subject: Re: Driving in the English countryside with the Garmin Quest |
Shaolyen wrote: | Does anyone know of a way to somehow lower the speed my Quest thinks I can drive on these roads, so it chooses the a faster route when possible? Please help, I'm desperate! |
No, you can't change the road speeds. I wish you could too.
Are you using "Faster Time" for your route calculations rather than "Shortest Route" ? _________________ Gone fishing! |
Posted: Thu Aug 04, 2005 10:42 am Post subject: Re: Driving in the English countryside with the Garmin Quest |
Skippy wrote: |
Are you using "Faster Time" for your route calculations rather than "Shortest Route" ? |
Of course, but the calculations are useless because of this road speed problem.
Does anyone know what the default speed settings are for the Quest? If we knew what to search for, perhaps a firmware hack would be possible. |
Posted: Thu Aug 04, 2005 1:33 pm Post subject: |
Can you post some examples of the routes so we can try it?
If you want to find out the road speeds, try this:
Go to the GPS Info screen, press menu, Use Indoors.
Then press Menu, New location and select the start point for your trip as the new location.
Now use the Find option to route to your destination.
After the Quest has calculated the route, it should ask if you want to simulate driving this route. Select Yes.
Now switch to the trip computer screen and you can see your speed. (Or change one of the fields on the map screen to show speed). This should give you an idea of the speed it is using for each road.
Hacking the firmware wouldn't be for the faint hearted but I would be interested to know if you actually find out where the speeds are stored.
I was under the impression that the Quest uses some adaptive algorithm for the speeds on different road types and learns as it goes. I don't know if this applies to routing or just the ETA.
Elsinga is a Garmin Guru, maybe he knows? Robert - are you reading this? _________________ Gone fishing! |
Posted: Thu Aug 04, 2005 1:36 pm Post subject: |
You could also try selecting a different vehicle type in the routing options and see if the routing improves, but that may give you strange results in other area. _________________ Gone fishing! |
Posted: Thu Aug 04, 2005 2:42 pm Post subject: |
Skippy wrote: | Can you post some examples of the routes so we can try it? |
I'll plug in my Quest later on and upload an example or two.
Skippy wrote: | If you want to find out the road speeds, try this:
Now switch to the trip computer screen and you can see your speed. (Or change one of the fields on the map screen to show speed). This should give you an idea of the speed it is using for each road. |
44mph on the narrowest roads. My actual speed is closer to 20mph.
Skippy wrote: | I was under the impression that the Quest uses some adaptive algorithm for the speeds on different road types and learns as it goes. I don't know if this applies to routing or just the ETA. |
You'd think that'd be the best way to do things. Or to selectively log frequently used roads for average speeds, so it can generate better routes based on past trip data. From what I can tell, it doesn't.
Skippy wrote: | You could also try selecting a different vehicle type in the routing options and see if the routing improves, but that may give you strange results in other area. |
That's a pretty good pretty. I've set my Quest to "truck" - hopefully it'll avoid the smaller roads wherever possible. I'll keep you up to date with how well it works. |
Posted: Thu Aug 04, 2005 2:44 pm Post subject: |
A "pretty good pretty"?! What am I on... I meant, a "pretty good idea". ;) |
rossb Regular Visitor
Joined: Nov 17, 2004 Posts: 79 Location: Sheffield, UK
Posted: Fri Aug 05, 2005 10:11 pm Post subject: |
I used to own a streetpilot III and was sometimes surprised when the unit routed me down roads not much bigger than my car.
On the relatively new streetpilot C320, there is a routing option to "avoid unpaved roads", which in theory should avoid roads like this.
Does the quest have this option? |
Posted: Fri Aug 05, 2005 10:40 pm Post subject: |
The Quest does have an "Avoid Unpaved Roads" option, but the problem is that these aren't unpaved roads. Unpaved roads are in my avoidances list, but it still takes me down these narrow roads.
As far as I can tell, setting the Quest to "Truck" mode makes no difference. I've uploaded a couple of example tracks here:
http://www.weavo.net/CountryRoads.gdb
This shows two tracks, from A to B and then back to A. For some reason the Quest gave a second route on the way back, which was much more difficult to drive along. Perhaps a bad example, as I was managing around 30mph on them - although I had to pull over onto the verge more than a few times. |
Posted: Fri Aug 05, 2005 11:28 pm Post subject: |
Thanks for posting the examples.
Looking at my AA road atlas I would have chosen the route via the A47 and Necton/Bradenham as the best one (presuming one would make better time on the A47) but you say the route via North Pickenham is a better! 8O
What it boils down to is that the satnav can't distinguish between the minor road types for the Necton route and the North Pickenham route. I think the road types are M, A, B, minor, residential and unpaved.
From what I can see of the tracklog, you managed a similar speed on both routes so technically speaking there isn't much to choose between them. Of course local knowledge/preference will dictate that you have a preference for one route over another, but you can't teach that to a machine unless the mapping provider categorised the minor roads into subcategories (which is unlikely to happen!).
Just be thankful you didn't buy CoPilot - it would have routed you via Dereham. _________________ Gone fishing! |
Posted: Fri Aug 05, 2005 11:56 pm Post subject: |
I've done some more testing, and it does seem that when the Quest is set to "Truck" mode it does make a significant difference when choosing routes. It isn't perfect, but I find myself using these narrow back roads less and less often. Thanks for the tip Skippy!
Skippy wrote: | Looking at my AA road atlas I would have chosen the route via the A47 and Necton/Bradenham as the best one (presuming one would make better time on the A47) but you say the route via North Pickenham is a better! |
The Necton/Bradenham route is a *tiny* road. The North Pickenham route is much wider. From what I've seen so far, the truck mode does try to avoid minor roads wherever possible, which definitely an improvement. |
