Pocket GPS World :: View topic - go 300 speed cam/ activation question
bestyman
PostPosted: Tue Aug 02, 2005 1:29 am    Post subject: go 300 speed cam/ activation question Reply with quote
Hi all,
Not sure about these go 300s as I have a classic.
A mate of mine has a 300 and wants speed cams and voices adding which I can easily do but ;
1. will it all fit on his card ( does the 300 still have a 128)
2. If I use a 256sd card will the card need activating with his product code? He claims he hasn`t got one/ dosn`t know where to find it. Obviously no CD so where is it supplied on the 300?
Is there a certain way to avoid putting the code in if he cannot find it? Would copying his card to PC then back again to 256 card work? I have read many conflicting opinions on this site about when the go needs and does not need a code. Also from personal experience I am totally confused by this activation code thing, seems no logic in when it is needed.
Mark
BrianI
PostPosted: Tue Aug 02, 2005 7:00 am    Post subject: Reply with quote
I Have have just got a GO 500, which comes with a 256Mb card. I got a larger 512Mb card so I copied the contents of the TT card onto my computer and then back onto the new card. No activation code is needed. First time I did it, I used a card reader and it did not work so then I used the GO itself to copy and paste. No problem. I have read elsewhere that it is important to use the GO to copy and past. Also keep a copy of the original files as a backup.
Brian
bestyman
PostPosted: Tue Aug 02, 2005 10:20 am    Post subject: Reply with quote
Thanks for reply.
Why did you get a bigger card than the 256? Reason I ask is that if a 512 is needed I`ll get me mate to bring one round with his GO.
Mark
BrianI
PostPosted: Tue Aug 02, 2005 1:13 pm    Post subject: Reply with quote
Hi Mark,
The 500 original files come to 216Mb and I wanted to add safety cameras etc, plus you need a bit of space for operating, so I went for the next size up. With a 300 you could go for a 256Mb card. The other advantage is i have the original tomtom card in case of any problems - plus a copy on my computer
Brian
22.044 (24 Apr 24)
