Pocket GPS World :: View topic - mio 168
mio 168
burrich
PostPosted: Thu Feb 24, 2005 10:28 am    Post subject: mio 168 Reply with quote
How long does it normally take for the unit to find the satellites? I installed the software,PrymeNav, selected autodetect gps....4800 baud and com2. I have got a Lat and Lon but sats 0.Am i missing something?
PostPosted: Thu Feb 24, 2005 10:37 am    Post subject: Reply with quote
You need a good uninterrupted sky view and should allow anywhere from 5 - 30 mins for the first out of the box fix.
You need to be outside for this.
burrich
PostPosted: Thu Feb 24, 2005 10:52 am    Post subject: mio168 Reply with quote
Thanks for that...took it outside and bingo!! It found 3 sats.Does it remember these or will it search every time i start it up?
PostPosted: Thu Feb 24, 2005 10:57 am    Post subject: Reply with quote
It needs to search every time it starts but only the very first fix takes so long, in normal use it should aquire a fix within a minute or so and often less.
Don't forget that a GPS receiver needs to see the sky so won't work or will work very poorly indoors!
burrich
PostPosted: Thu Feb 24, 2005 12:18 pm    Post subject: mio 168 Reply with quote
Hi...again. My Mio 168 is telling me no gps found,reconnect and rescan.I dont know what has happened...can anybody help
PostPosted: Thu Feb 24, 2005 12:25 pm    Post subject: Reply with quote
Soft reset the unit (insert the stylus tip into the 'reset' hole). Then configure PrymeNav for COM2 and 4800bps rather than allowing it to seek the settings automatically.
burrich
PostPosted: Thu Feb 24, 2005 12:31 pm    Post subject: mio 168 Reply with quote
Thanks for that....i was doing my nut in!!!!!!
PostPosted: Thu Feb 24, 2005 12:38 pm    Post subject: Reply with quote
Now you know why they call this 'bleeding edge technology'. It's your head that's the bleeding edge and the technology that's the cause ;)
Donald
PostPosted: Sat Jul 23, 2005 8:49 am    Post subject: Re: help Reply with quote
ducky wrote:
I have the same issue with my h2215 and the Pocket Track.
It doesn't find any sattelite at all. I am using com 1 4800 bauds.
My navigation software is iGuidance.
what else should I try?
ducky
I suggest you start a NEW TOPIC with the title "Help rqd with H2215 setting up GPS". That way folk with H2215 knowledge will respond
This is a MIO 168 thread and H2215 users may not open it and see your needs.
Please do not respond to this post. Keep the thread ON the Mio topic.
Axim X50 & TT5, Arkon CM820 powered mount with built in sirf2 gps
Axim 5 sans GPS Rx
Ford Focus 2L Ghia, Wife, kids, dog, cats, mortgage, bank manager & taxman to support, debts, windows need painting - (I cut the grass! - its rained - it needs
ducky
PostPosted: Sat Jul 23, 2005 9:03 am    Post subject: help Reply with quote
ducky
