Pocket GPS World :: View topic - Make your own GO 300 External Antenna
Renfield
PostPosted: Wed May 18, 2005 6:23 pm    Post subject: Make your own GO 300 External Antenna Reply with quote
Just thought you'd like to know that you can modify the new GO 300 mount to include the external aeriel from the old Antenna kit.
Here's what you need: 1 x Torx T6 Screwdriver, 1 Torx T8, 1 x Tomtom GO External Antenna (Part no. ID00.001).
Method:
Peel back the thin end of the rubber pad on the bottom of the GO external antenna mount to locate two T6 screws. Remove these and unclip the base. Underneath you will find a metal plate with two T8 screws in, remove these and the plate comes off. Rotate the top of the mount and it pops out from the base. Underneath the metal ring are two more T6 screws. Remove these and take the plastic plate off. From here you can remove the aeriel connection from the top of the mount.
Repeat the above process to disassemble the mount for the GO 300. On the top of the mount, where the connector is, peel off the black sticker around the connector and you will find that it covers a hole already there for the aeriel to fit in (the mount contains all the fittings for the external antenna). Place the antenna into the GO 300 mount and re-assemble.
Hey Presto! Aeriel mount for the GO 300 for those who don't want to wait for Tomtom to release the new kits. Did this today as my car has an Anti-Thermic coat on the windscreen, now have a brilliant signal all the time.
Laughing
Frazzle
PostPosted: Wed May 18, 2005 7:01 pm    Post subject: Reply with quote
I'm kicking myself that I didn't think of that before !
An excellent solution which does make you wonder WHY TomTom do not seem able to supply the TTG300 mount as it's only a reconfigured TTG mount.
Great post Renfield :D
Eldar
PostPosted: Wed May 18, 2005 9:35 pm    Post subject: Reply with quote
I'm too fragile to kick myself, but I can come and kick you for the both of us - never crossed my mind either.....
JDbubbles
PostPosted: Thu May 19, 2005 5:39 pm    Post subject: Reply with quote
I have just done this today,and it is superb.It was pretty easy to do and I am as ham fisted as they come.They only problem I had was working out where the 2 spare screws came from.(had to take it apart again to find out).
Overall though it has transformed my TTG300 and I would definately reccommend it for anyone having the windscreen problem.
A big thanks to renfield for the info !!!
PostPosted: Thu May 19, 2005 5:42 pm    Post subject: Reply with quote
Excellent description Renfield.
I have made this topic sticky so it doesnt get lost. :D
sgould
PostPosted: Wed Jun 15, 2005 9:27 pm    Post subject: Reply with quote
Would there be a problem shortening the cable so the the connector is almost "chassis mounted" to the GO base? I attach the GO to the bottom right of the windscreen, so the standard metre of cable would just dangle behind the steering wheel.
If I get an aerial I would want to keep the detachable bits to a similsr size to the present with a short length of aerial cable coming out of the A pillar to the bracket.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps
smallfreak
PostPosted: Thu Jun 16, 2005 9:23 am    Post subject: Reply with quote
Please think about the fact, that this is a "high frequency signal" cable, not a low voltage power cord or serial-data connection. Cutting off the wrong length and/or mounting the connector without the propper tools can introduce signal reflections and easily reduce the signal strength down to zero which renders the antenna useless.
You are dealing with "microwave transmission" here.
I don't say you WILL damage it, but you risk doing it.
Solitary_Trucker
PostPosted: Sat Jul 16, 2005 4:06 pm    Post subject: Make your own GO 300 External Antenna Reply with quote
Thanks for the great advice and detail given in this article. I like many others proberly kept looking on E-bay at the external antenna and mounts but feel ripped off i have to buy anothe rmount on top of my 500 price. Ok so you can modify your 300/500/700 mount had a look and took it to bits not to hard it seems not having a classic mount and aerial to hand can anyone tell me if i can use any external aerial instead of a genuine go classic one as i have about 5 different aerials with different connectors from other GPS units kicking around the house. Thanks for any help
22.044 (24 Apr 24)
