Pocket GPS World :: View topic - Holux GPSlim236 & TTN5 conectivity
dask
PostPosted: Wed Jul 06, 2005 2:46 pm    Post subject: Holux GPSlim236 & TTN5 conectivity Reply with quote
I have an Ipaq 3970 with SD card & TomTom navigator 5 loaded & have just purchased a Holux GPSlim236. I can get the Ipaq to see the Holux using the GPS Viewer installed (supplied by Holux), but I can not get TTN5 to see the GPS receiver.
The Holux is set for SPP Com Port 8, Baudrate 38400 in GPS Viewer on the Ipaq & other Bluetooth GPS, on SPP Com8 in TTN5 'Specify your GPS Hardware'.
The Holux is bonded to the Ipaq & Bluetooth Manager seems to connect to it OK, with a good signal.
Can someone please help????
DinAlt
PostPosted: Wed Jul 06, 2005 3:07 pm    Post subject: Reply with quote
Download the 2.06 driver for Tomtom 3 and run this first - you normaly have to run it twice - once to set the rihgt settigns and once for it to run.
After running it succesfuly once TomTom 5 will now use the correct port.
Note of warning - don't try plan a route using the advanced setting without your receiver on because after you do it TomTom 5 will no longer recognise teh receiver and you'll have to repeat teh "boonding" procedure above.
Hope this helps,
DinAlt
DinAlt
PostPosted: Wed Jul 06, 2005 3:08 pm    Post subject: Reply with quote
Oops forgot to mention you can dowload the gps driver from this site - (dowwnloads section).
DinAlt
dask
PostPosted: Wed Jul 06, 2005 5:19 pm    Post subject: Holux GPSlim236 & TTN5 conectivity Reply with quote
Thanks, but while looking for the driver I found the answer on the TomTom web site. All now working ok.
Thanks All.
C00LH4ND
PostPosted: Fri Jul 08, 2005 12:38 pm    Post subject: Reply with quote
What was the solution you found on the Tomtom website.. Please share the knowledge :D
________________________________________
C00LH4ND
IPAQ 2210; 256Mb CF & 256Mb SD
TT 3.07, Checkpoint 3.2.0.0, TT Nav 3
jonas
PostPosted: Mon Jul 11, 2005 10:48 am    Post subject: Reply with quote
Here's the solution:
http://www.tomtom.com/support/rightnow.php?Page=http%3A//62.250.17.58/cgi-bin/uk.cfg/php/enduser/std_adp.php%3Fp_faqid%3D3236%26p_created%3D1119370927%26p_sid%3DsxDo_9Kh%26p_lva%3D%26p_sp%3DcF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MzUmcF9wcm9kcz02MiwwJnBfY2F0cz0mcF9wdj0xLjYyOzIudTAmcF9jdj0mcF9zZWFyY2hfdHlwZT0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1ibHVldG9vdGg*%26p_li%3D%26p_topview%3D1
The link is long but it explain everything.
Regards.
22.052 (08 May 24)
