Pocket GPS World :: View topic - 12V cig lighter adaptor faulty?
tomjeffs
PostPosted: Sat Jun 25, 2005 5:54 pm    Post subject: 12V cig lighter adaptor faulty? Reply with quote
Just a quick note to people, the small copper coil located inside the 12V regulator plug on the wired GPS system is a weakpoint.
The other week mine started flickering on and off, and was useless. Opening the plug up (easy to do, doesn't break it) showed that the coil was secured by epoxy, which had broken loose, and then one of the legs from the coil had worked its way out of the circuit board. Soldered it back in and its fine.
Should anybody's plug start doing similar things, check that coil first - its dead obvious, one of the largest components on the board. I'm not surprised it came loose, the amount of glue holding it was tiny.
22.051 (01 May 24)
