Pocket GPS World :: View topic - Ipaq 4150, Clip-on, TT5 - help please!
viper8
PostPosted: Wed Jun 22, 2005 9:37 pm    Post subject: Ipaq 4150, Clip-on, TT5 - help please! Reply with quote
Hi all,
i had TT3 running on my Ipaq 4150 and Clip-on with no issues at all. Just upgraded to TT5 and it wont see my Clip-On! I paired the device with no issues, went into TOMTOM gps v3.07 and select com6 with 33840. It shows the Sat no problems. Soon as i startup TOMTOM5 is says no GPS device. Going into the GPS setting via TOMTOM5 select other Bluetooth device and com 6, it won't pick anything up. Then the connection between the Ipaq and clip-on drop's.
Tried a few things, installed an older version of TOMTOM Gps 2.06 and 2.07, still that didn't work. Problem is after installing the older version of TOMTOM gps, there is no com6 option anymore? Inside my Ipaq bluetooth setting the outgoing port is com 6 which i can't change.
Is it possible to change the com setting on the Ipaq to com 5?
have i missed something?!?!?
thanks. Rolling Eyes
paul_w
PostPosted: Fri Jun 24, 2005 11:24 pm    Post subject: Reply with quote
Try this - it worked for me.
Pair the devices, then start up TT5 and take the following steps...
Main Menu page 1 - "Change Preferences"
Preferences Menu page 4 - "Show GPS Status"
Choose Configure button
Scross to "Other Cable NMEA GPS", then Select
Set GPS Baud rate to 38400
Choose "Bluetooth Serial Port COM6:" - this is the last item in the list on my screen
Select the clip-on from the Bluetooth browser screen
This should then connect the two.
ps my clip-on is set to XT - not sure if this matters re the above
good luck
viper8
PostPosted: Sun Jun 26, 2005 8:50 pm    Post subject: Reply with quote
Laughing Laughing Laughing Worked like a treat! I had to switch to XT first before it worked, then switched back to ST with no problems.
many thanks!!!
cheers....
