Pocket GPS World :: View topic - Streetpilot 2610 & Speed cameras
mrstella
PostPosted: Sat Jun 18, 2005 10:48 am    Post subject: Streetpilot 2610 & Speed cameras Reply with quote
Hi All
Just got a 2610 from work and would like to get some speedcamera POI's for it.
However i have 1 problem, i have not been supplied any software or usb cable etc with the unit. Or instructions 8O
I can read the memory card on my pc so i can copy anything to the memory card no problems.
I have downloaded the speed camera pois and installed them on my pc, however i have copied the image file to the unit but cant seem to get it to work.
Any help would be great.
Regards
Peter
ferret79
PostPosted: Sat Jun 18, 2005 10:19 pm    Post subject: Just got a 2610 from work Reply with quote
Hi, as regards the speed cameras for the Garmin 2610... it wont work as it garmin don't cater for speed camera software as yet....As regards instructions (book) you can download it from www.garmin.com then print it out (make sure you have a full wad of paper though)......
Regarding the software it is "unit id software related" and would depend on what version you need ...5..6..or.7 you would be advised to contact the person you had the unit off, failing that contact Garmin but be prepaired for a shock caus it wont be cheap...Hope this helps.
Skippy
PostPosted: Sun Jun 19, 2005 12:39 am    Post subject: Re: Streetpilot 2610 & Speed cameras Reply with quote
You MUST get "Mapsource" and the software unlock codes from the previous user. You can't do much without it. As ferret79 says, you can get a copy of the manual from Garmin.com.
For the speed camera database, see the map that Wired has created. Garmins will display the locations but a major limitation is that they don't do proximity alerts. :x
WIReD wrote:
The Garmin POI map is now available for download from my temporary website, which is http://myweb.tiscali.co.uk/walterwright
Gone fishing!
