Pocket GPS World :: View topic - Problem installing Pocket gps camera
newuser55
PostPosted: Sun Jun 12, 2005 6:51 pm    Post subject: Problem installing Pocket gps camera Reply with quote
Hi, I have just bought a TTG300. I read the info on how to install the pocket gps camera data base. I downloaded it, unzipped it & copied & pasted intially ov2 bmp, then added alternative bmp then single version & lastly speed zoned. All of these into my Great Britain map.
After each one I went into manage POI & I could see no new POI to 'set'.
I think I have added too many files but could someone please assist by telling me exactly which files I should have added & also am I correct in thinking I should be able to view a new POI in the list marked speed camera or something similar which I then should be able to 'tick'.
Dazp
PostPosted: Sun Jun 12, 2005 8:11 pm    Post subject: Reply with quote
I actually pasted the ov2 and bmp files into the GB_Navigator ie not the GB_Map folder and mine work fine...which for me, is good Wink Laughing
wez99
PostPosted: Sun Jun 12, 2005 8:22 pm    Post subject: Reply with quote
Did you paste the files or the folders. If you pasted the foders it will not work. You need to delve inside the folders until you see the individual files and copy/paste those.
TomTomGo730
newuser55
PostPosted: Sun Jun 12, 2005 9:39 pm    Post subject: Reply with quote
Thanks Wez99, I had added the folders not the files. I have now added all the files in ov2bmp & its working.
Do I need to paste any more? :D
wez99
PostPosted: Sun Jun 12, 2005 10:06 pm    Post subject: Reply with quote
If you want a visual guide to the speed zone each camera is associated to then download the speedzoned cameras. I find that if you give the speedzoned cameras a slightly different warning distance than the ones you have already installed, all will work well.
Hope this helps
John
TomTomGo730
22.044 (24 Apr 24)
