Faust Regular Visitor
Posted: Thu Jun 09, 2005 12:06 am Post subject: I can't hear any voices |
I am having difficulty with the voice POI's for the speed camera database and wondered if I am doing anything wrong when doing the install. I already have the POI speed camera database with whistles and bells etc. working without a hitch, but when I download the spoken voice alerts I get nothing when trying the test alert. I have a new GO 300 with latest firmware 5.10 installed and I downloaded the data.chk file 5158. I used the card reader on the PC to make the alterations and did the following. I renamed the original data.chk file as dataold.chk and then copied the new 5158 file to the SD card and renamed that with the name of the original i.e. data.chk I then put the card back in the TomTom, turned it on, went to manage POI's, selected a couple of the cameras, pressed the test button, and absolute silence. Have I missed doing anything.....? |
lbendlin Pocket GPS Staff
Posted: Thu Jun 09, 2005 1:06 am Post subject: |
please send your original data.chk so we can verify. Are you sure you have build 5158? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Eldar Pocket GPS Moderator
Posted: Thu Jun 09, 2005 10:06 am Post subject: |
If you are not hearing any voices you've been cured :P |
Posted: Thu Jun 09, 2005 11:10 am Post subject: |
lbendlin wrote: | please send your original data.chk so we can verify. Are you sure you have build 5158? |
Yes, according to the build info screen that is exactly what I have, and have upgraded 300 firmware from the 5.0 it came with to 5.10 . To whom do I send it and from which link? |
PJEvans Regular Visitor
Posted: Thu Jun 09, 2005 11:36 am Post subject: Re: I can't hear any voices |
Faust wrote: | I renamed the original data.chk file as dataold.chk and then copied the new 5158 file to the SD card and renamed that with the name of the original i.e. data.chk |
Faust
Could it be that the name for the old file is simular to the new one? When I did mine, I just renamed the old one 'old sounds'.......Just a thought |
Posted: Thu Jun 09, 2005 8:49 pm Post subject: |
I have emailed the file to Lutz as per his request. I have tried everything, every combination, but the gatso voice option will just not work on this TomTom unit. |
rkm_hm Frequent Visitor
Joined: Nov 28, 2004 Posts: 532 Location: Warwick, UK
Posted: Thu Jun 09, 2005 10:02 pm Post subject: |
You haven't inadvertently turned off all sound - or turned off "Warn when near POI" have you?
What happens if you rename the new data.chk file to (say) data.ch$ and then rename the original one back to data.chk? Do you get your bells and whistles back? If so, there's something wrong with the new data.chk file. If not, the problem lies elsewhere. _________________ Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire |
sgould Frequent Visitor
Posted: Thu Jun 09, 2005 10:14 pm Post subject: |
You have actually gone through the process of "warn when near PoI" for each and every one of the cameras for different speeds, setting the voice and distance each time? Just installing the new data.chk won't get the voices. |
Posted: Thu Jun 09, 2005 10:48 pm Post subject: |
Roger I tried what you suggest i.e. renaming new file and reverting back to old - I am back to bing bongs, bells etc straight away. My build version is the same as yours App 5.100 (5158/050510) OS 832 I have also gone through the warn when near POI and put in all the distance settings again. There must be something wrong with the 5158 new data chk file or something. |
Posted: Thu Jun 09, 2005 11:30 pm Post subject: |
At last I have got it to work. However, I have had to remove the original data chk file completely from the SD card. Renaming the file with whatever name does not fool it - odd. All I need now is some assistance with the various speeds. Do I have to assign a voice for each gatso speed limit or is that part of it automatic after as an example just selecting Beep 1 for gatso. |
Posted: Fri Jun 10, 2005 11:00 am Post subject: |
Well as stated previously, I have now got the voice files to work with the speed camera database, although there are quirks which I would like some advice about. First off, using the original SD card map which has not been corrupted in any way. Although I renamed the original data.chk file with various other names then called the new 5158 file data.chk the voices simply would not work. Finally I downloaded the 5158 file yet again and attempted the process once more. This time (and this happens whichever way I try to do it) I get an error message when trying to keep both the old and new data.chk files on the one card. The message states “error unable to complete transfer cyclic redundancy” If I remove the original file then everything works OK. The really odd thing though is that when I attempt the same process on my combined map SD card i.e. GB and France the transfer goes without a hitch, both old file with another name and new file on the on card……?
Next the actual voices. I have assigned each beep or bugle with the correct tag e.g. UK gatso beep 1 or beep 2 for gatso 30. I did this through manage POI,s then when prompted remove warning yes or no, I pressed no, then checked the yardage clicked done left warn when near POI unchecked and started process again selecting UK gatso again, then moving onto next tag e.g. Beep 3 gatso 40 and so on and so on. However, I noticed on my way to work today that although I get the warning message gatso, I do get anything to denote speed e.g. warning gatso 30 or 40 or whatever the speed limit is – should I be getting this information. The cameras I pass on my way to work are many and in various speed zones, but all I get is gatso. A long post I know, but I would appreciate some advice as I am somewhat puzzled. |
xda Lifetime Member
Posted: Fri Jun 10, 2005 2:16 pm Post subject: |
I think your problem is that TT V5 POI warning features are severely limited in what it can achieve when compared to TT V3 running with either CheckPOInt or GPSAssist as you can't use wave files associated with each individual speed related camerae group to tell you what the speed limit is. Hopefully TT will release a SDK file for V5 to enable the use of 3rd party add-ons. Although I have ordered the upgrade I will stay with V3 as I like my spoken voice warnings such as "Warning approaching a Gatso" followed by a second warning "The speed limit is 30 mph" _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Fri Jun 10, 2005 2:39 pm Post subject: |
Faust wrote: | However, I noticed on my way to work today that although I get the warning message gatso, I do get anything to denote speed e.g. warning gatso 30 or 40 or whatever the speed limit is – should I be getting this information. The cameras I pass on my way to work are many and in various speed zones, but all I get is gatso. A long post I know, but I would appreciate some advice as I am somewhat puzzled. |
I've passed some camera's that also don't give the speed. I always thought that it was because when they were reported to whoever puts them on the database that a speed wasn't specified, and that they are then put into a general category of Gatso, hence no speed warning. |
Posted: Fri Jun 10, 2005 3:49 pm Post subject: |
xda wrote: | I think your problem is that TT V5 POI warning features are severely limited in what it can achieve when compared to TT V3 running with either CheckPOInt or GPSAssist as you can't use wave files associated with each individual speed related camerae group to tell you what the speed limit is. Hopefully TT will release a SDK file for V5 to enable the use of 3rd party add-ons. Although I have ordered the upgrade I will stay with V3 as I like my spoken voice warnings such as "Warning approaching a Gatso" followed by a second warning "The speed limit is 30 mph" |
Well if that information is correct, then you completely burst my bubble I was looking forward to the speed limit is warning. To be quite honest given that information and assuming it is correct I may as well go back to the bells and chimes, which I think actually have more impact. If the added speed indication was present on the TT GO300 then I would opt for voices, but just the word Gatso doesn't quite cut the mustard as far as I am concerned. :x |
