Pocket GPS World :: View topic - Install TT3 & TT5 on same iPAQ?
Glyn
PostPosted: Thu Jul 14, 2005 9:16 am    Post subject: Install TT3 & TT5 on same iPAQ? Reply with quote
Hi there,
Would it be possible to install both TT3 and TT5 onto my HX4700 or 2210 with no compromises?
Thinking about it if I installed say TT3 on to the SD card and TT5 onto the CF card (or two seperate cards of the same type if there is a speed advantage) would this work?
Is there anything else that has to be written to main memory that could cause conflicts?
Is there any advantage to using high speed CF/SD cards on the iPAQ?
Is any one faster than the other when used in the iPAQ?
Thanks & regards,
-=Glyn=-
lbendlin
PostPosted: Thu Jul 14, 2005 4:24 pm    Post subject: Reply with quote
you cabn install both programs even onto the same card into different folders. They do not interact in any way (unlike TTN2 with TTN3)
If you want to use the latest maps with TTN5 then you need to store two independent map versions too. TTN3 cannot use the TTN5 maps.
Lutz
TomTom/TeleAtlas NAVTEQ
Conor
PostPosted: Mon Jul 25, 2005 3:10 pm    Post subject: Reply with quote
I tried it and couldn't get it to work.
