Pocket GPS World :: View topic - TTN5 & other bluetooth
Goto page Previous  1, 2, 3, 4
davwil
PostPosted: Tue Jun 21, 2005 10:54 pm    Post subject: New TomTom FAQ about Bluetooth GPS Reply with quote
Hidden away on page 3 of 3 in product FAQ's there is a new FAQ about Bluetooth connections - whish I had tried this before I hard reset my hx4700....
Start from this URL..
http://www.tomtom.com/support/rightnow.php?ID=4&Language=1&M=0&Page=std_alp.php
Cheers David
korndog
PostPosted: Tue Jun 21, 2005 11:11 pm    Post subject: Reply with quote
I have just upgraded to TTN5 and didn't have a problem getting my Leadtek bluetooth to work with my XDA. I just se t it to comm port 5 and off we went.
iwatsonhome
PostPosted: Thu Jun 23, 2005 3:44 pm    Post subject: Hoorey TT5 HP2210 Rikaline 6010 finally working!!! Reply with quote
Laughing After many registry adjustments and trying all NMEA settings, I would get the spinning symbol in tt5 gps but always "no device found" - but.....
Download 3.07 GPS, install, and configure for correct receiver with comport 8 - once connected and you can see satilites, soft reset and start TT5, may have to reselect NMEA device, baud 4800 bluetooth com8 again. Good luck!!!
Link as follows for 3.07 GPS:
http://www.tomtom.com/support/rightnow.php?Page=http%3A//62.250.17.58/cgi-bin/uk.cfg/php/enduser/std_adp.php%3Fp_faqid%3D1435%26p_created%3D1083913757%26p_sid%3DI3EQ6IIh%26p_lva%3D%26p_sp%3DcF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTc3JnBfcHJvZHM9MCZwX2NhdHM9MCZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX2ZubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWJsdWV0b290aA**%26p_li%3D%26p_topview%3D1
technik
PostPosted: Thu Jun 23, 2005 11:08 pm    Post subject: Reply with quote
I did the registry edit and selected other wired gps, and now my Ambeon GPS works fine on COM 8 :D
Thanks to OP :D
mcddrums
PostPosted: Fri Jul 01, 2005 12:55 pm    Post subject: Reply with quote
The download above (tom tom gps prog) sorted it out for me. My bluetooth gps receiver wasn't even listed so I used the 4800 setting. This then gave me a port 8 in the list whereas I had previously only had bluetooth port 5 listed twice. It now works and Im very pleased!!!
Good luck
NSaints
PostPosted: Wed Jul 06, 2005 10:51 pm    Post subject: Reply with quote
Adding the registery entry (BtBrowserEnabled) resolved my problem. Would this mod have to be done if my PDA was ever 'hard' reset?
h-swe
PostPosted: Sat Jul 09, 2005 7:02 pm    Post subject: TomTom Navigator 5 and Bluetooth-GPS Reply with quote
At last, it works - TTN5 + BT GPS
Hi to all of you with problems getting TTN5 working with Bluetooth-GPS
( HP hx4700 + ClobalSat BT-338 )
Copy your TTN3 ( gps.ppc3_arm.cab ) to a temp folder and rename it
(gps.cab), then replace the one that is in the installation folder of TTN5
( search fore gps.cab if you do not know where it is )
If you do not have TTN3 gps driver, DOWNLOAD TTN3.07 update
(ttnupd307.zip) Extract it then Run (setup.exe) it will extract the files
for you - gps folder...!
Uninstall the TTN3 or TTN5 and do a soft reset, then use the
new installation Or even better, do a Hard Rest, to make sure no old
files or RegEntries still there...
P.S.
You will have to fix the file (TomTom Navigator.exe) to remove the VGA
support from it using ResHac as published before
(use Resource Hacker, to delete the key named 2057 in CUEX -> HI_RES_AWARE)
In GPS config, use other Cable NMEA GPS + port number )
Hope that is of any help....
zeon
PostPosted: Fri Jul 15, 2005 11:21 pm    Post subject: TomTom 5, XDA II and Globalsat BT-338 Reply with quote
I've tried everything to get TT5 working with the BT-338 but it wont connect tried the Bluetooth settings, the serial, all baud rates all ports and nothing. also reset the XDAII and only installed TT5 and bonded the BT-338 and nada. Sad Any suggestions anyone.
TT5 works fine with my old sysonchip CF_GPS but that defeats the object of the Bluetooth. TT4 works with the BT-338 fine. I'm v puzzled.
zeon
PostPosted: Sat Jul 16, 2005 12:27 am    Post subject: Re: Info Requested Reply with quote
lucho wrote:
Open your registry editor on your PPC.
Browse to: HKEY_LOCAL_MACHINE\Software\Widcomm\AutoConnect\000x ("x"
is the number of the com port your GPS operates on, mine is on Com7 so
I navigate to "0007").
Locate the key
Load up TomTom and go into the preferences and re-setup your GPS
Receiver. It should work now...
Thanks Tim for this info.
Lucho
I've tried editing the registrybut neither keys exist in mine. My BT-338 is on com7 where in the registry would I create the key: "BtBrowserEnabled" and change it from "1" to "0".?
RichDem
PostPosted: Sat Jul 16, 2005 7:15 pm    Post subject: Reply with quote
I don,t know if this will help anyone but I could not get my Qtek 2020 (XDAII) to connect to my BT-338 even using the "other wired method"
what I did find was that if you go to the bluetooth option in the settings there were two boxes, one for incoming bluetooth and one for outgoing bluetooth.
Once I had checked both of these boxes I then paired my pda with the 338. Launched TomTom and low and behold I tried the "other bluetooth" option and everything sprang into life.
Hope this helps.
If it ain't broke then fiddle with it until it is!
Getssmart
PostPosted: Wed Jul 20, 2005 10:20 pm    Post subject: Reply with quote
Trevor1234 wrote:
....The Receiver is brilliant and receiving satellite data and sending it to my PDA....
How do you know this to be so, is there a method that I can use to test the output from a GPS receiver?.
Please answer fully as I am a bit new to all this, thanks.
BTW I am using a C500 not a PDA.
Mike
I hate technology !....or is it technology that hates me?
Page 4 of 4
22.052 (08 May 24)
