Pocket GPS World :: View topic - TMC reception and messages
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC)
dio
PostPosted: Wed Apr 20, 2005 9:26 pm    Post subject: TMC reception and messages Reply with quote
I am running Navigon 4.2 on a FS Loox 420 with the wired GPS mouse and TMC module. My problem is that when I leave the house every morning the TMC module picks up Classic FM and starts counting up the messages.
When I get onto the M5 south at junction 4a the TMC light turns orange and doesn't regain any signal until I get off the motorway at Junction 7 (Worcester). When I get a green signal again it is locked onto Wyvern FM and the previous messages start to disappear. I travelled to Bristol today and despite selecting 'lock Classic' when I had a signal, this changed by itself in Bristol and locked to a local station, again the messages already logged were deleted.
Is this a question of the Classic FM signal not being picked up by the provided antenna or is it alternative TMC data signals that Navigon cannot decipher ? Would a Y splitter help to route my car antenna to the GPS mouse ?
Any help or suggestions gratefully received !
chris_w
PostPosted: Fri Apr 22, 2005 9:19 pm    Post subject: Reply with quote
Hi There,
I have Navigon too - I can only tell you what I have experienced.
Yes you will get a patchy signal from time to time - I personally feel it has something to do with the small ariel. Saying that I've always managed to pick up enough of a signal to get warnings etc and I have driven all over the country with it.
The y splitter should help as it will pick up a better signal as long as the station is acailable in that area.
dio
PostPosted: Sat Apr 23, 2005 8:59 pm    Post subject: Reply with quote
Thanks Chris, I think I will order the splitter and see if that makes the reception of Classic any better. The most annoying thing is when it locks onto another station and deletes the messages , not sure if there is a way round this though.
I went out today and after receiving 30+ messages on the M6, and locked to Classic it suddenly locked to a local station and deleted 15 messages before I told it to retune. When it picked up Classic again I locked it and it stayed with the signal for the rest of the journey.
I'll post a message when I get the splitter an (hopefully) a better lock on Classic.
chris_w
PostPosted: Sat Apr 23, 2005 9:14 pm    Post subject: Reply with quote
Let me know how you get on.
I'm tempted to buy one myself
Petekk
PostPosted: Wed May 04, 2005 4:49 pm    Post subject: Reply with quote
Where did you buy your splitter from? Recommended? or not?
dio
PostPosted: Wed May 04, 2005 11:59 pm    Post subject: Splitter Reply with quote
Not ordered it yet, I was wondering whether there was an alternative or if I do buy it - whether I can extend it so I can run the GPS mouse away from the dashboard.
Petekk
PostPosted: Thu May 05, 2005 11:33 am    Post subject: Reply with quote
Should be able to. Either by extending the aerial lead or the lead from the Y to the TMC unit. All fittings seems to be fairly standard and avaliable from maplin
DaveMatthews
PostPosted: Sat May 28, 2005 2:09 pm    Post subject: Reply with quote
You should find the Y-splitter improves reception of Classic greatly - however there are still geographical "black holes". I commute from Lancaster to Blackpool and when I was still using the bit of wire supplied as standard with Navigon, reception of Classic was so patchy, it was virtually useless. Fitting the Y-splitter has helped greatly but I still usually lose Classic about five miles north of Preston. I can just about get a (very feeble) signal as I travel along the M55 but it's still very patchy. I put this down to the fact that the so-called "Morecambe Bay" transmitter is on low power and is actually located near Barrow!
In conclusion, the Y-splitter is a must-have but I think you're ultimately at the mercy of Classic's transmitters, in terms of geographical dispersion and power.
dio
PostPosted: Sun Jul 03, 2005 12:11 pm    Post subject: Reply with quote
Well I have finally got round to ordering the Y splitter from Navigon, I will post the outcome in couple of weeks !
Navsteve
PostPosted: Fri Jul 08, 2005 11:38 am    Post subject: Reply with quote
Hi There, Finally got through to Navigon and complained about the lack of TMC on MN 5 to their Support Line. They told me that they are aware of the problem and that in about 2 weeks there would be a download to correct the problem. Hopfully this means TMC in UK will be available to MN 5 users like me. :D
Steve.
dio
PostPosted: Mon Jul 11, 2005 10:20 pm    Post subject: Y Splitter update Reply with quote
OK, got the splitter from the Navigon website 49 euros incl delivery. Its actually the same one that is on the http://www.gns-gmbh.com/en/ site only the delivery from Navigon is only 9 euros (and is still came in a 8 days)
Anyway, I drove to work today and managed to keep the Classic signal all the way there and back which was a fantastic improvement and for once I felt that the Navigon was doing what I bought it for !!
However (there's always a downside !) - when I went out at lunchtime and turned on Navigon the TMC had tuned on to a local station (Wyvern) and the 'Lock' status had changed from Classic to Wyvern. I can't see why Navigon changed what I had set it to earlier other than I understand that Wyvern broadcast TMC messages Navigon can't decipher (which is frustrating as they are a GWR group member)
Anyone else had the same problem with the Lock status changing ?
Does anyone know if there is anything we can get done about the other GWR stations broadcasting TMC that Navigon can't read and cause your stored Navigon messages to be deleted ?
dio
PostPosted: Fri Aug 26, 2005 7:47 pm    Post subject: Reply with quote
My current set up with the Y splitter (and now Bluetooth) is a vast improvement but I'm still annoyed about the 'Hold' station changing of its own accord.
I'm wondering whether Navigon would consider a patch to make the 'hold' option act like a normal FM radio and hold the station (retuning as you move round the country) regardless of whether it was transmitting TMC info all the time ? I appreciate that this may only be useful in the UK as we only have Classic FM broadcasting TMC that Navigon can use.
Anyone got any thoughts / advice ?
chris_w
PostPosted: Fri Aug 26, 2005 8:33 pm    Post subject: Reply with quote
Dio,
I agree that the Navigon RDS TMC lock can be a pain. Mine tends to get stuck on Century FM.
As far as I know there is no fix or workaround for this. Also I doubt Navigon will delelop a patch for it now as they have released Navigon5 - even if the TMC isn't supported in the UK.
Thanks,
Chris
dio
PostPosted: Fri Sep 02, 2005 12:07 am    Post subject: Reply with quote
I've emailed Navigon UK support for what its worth to see if they agree with the problems and to comment on a patch to fix. I don't hold out any hope for a response !
I would have thought that with Version 5 not supporting TMC in the UK they would offer some help to 4.2 users to make it a truly worthwhile product.
I feel a bit cheated after the cost of a full Bluetooth and TMC set up.
chris_w
PostPosted: Fri Sep 02, 2005 9:35 am    Post subject: Reply with quote
Totally agree,
I have no time for this company any more Grrrr
Thanks,
Chris
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Traffic Message Channel (TMC) All times are GMT + 1 Hour
