Newsletter
Pocket GPS World :: View topic - Destinator2 & O2 XDA
gardgas
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Destinator2 & O2 XDA Reply with quote
Hi, I wonder if anyone can help me. I purchased Desinator for use on my O2 XDA last Xmas. I worked perfectly from the off, infact I was most impressed with it. A couple of weeks ago whilst on the O2 website I noticed a ROM upgrade available for the XDA, which I downloaded and installed, again all appeared to to go OK. I had to reinstall Destinator, along with everything else I use. But since this Destinator has been very unreliable. It loads and starts ok but then freezes, or gives the impression it has lost the satelites. I check all the cables, the gps status screen and get either "no satelites available" or "port in use", then everything locks up and I have to do a reset. Any ideas please as I am an IQ zero when it comes to the technicalities. One thing I wondered is if the memory of the XDA (32Megs) is too low, but is has worked ok in the past.
Many thanks
Nigel
TheGoodMan
The minimum requirement for Destinator is
Pocket PC device
Compact Flash jacket for your PDA, if needed
RAM of 64M or compact Flash memory card 96MB or greater
Try to re-set the PDA by pressing the reset button and see if it works or not
Goodman
Can you downgrade the ROM ? Many iPAQ users have found the ROM upgrades can seriously interfere with Navigation software, it sounds to me that the ROM could be causing the problem. If you can downgrade the ROM and it works okay, then I'd contact Destinator Support and ask them to look into it.
StuBFrost
Make sure that infra-red is not enabled. This grabs COM1 if it is.
Stuart Frost
20.054 (25 May 22)
Terms & Privacy
